Foto Cell + Andeli Contactor Installation - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 04:04 PM   #1
Hi, I am trying to replace a Photo Cell and Andeli Contactor from an existing 220 volts circuit which had been working properly. I have installed the new components but nothing happened. One point is that although I had a 220 circuit a 110V Contactor was in there so I have replaced it with a 220V contactor. If I connect the Photo Cell Wires in the same way a noise come up.
What should I do ???
Many thanks !!!
Ricardo Medina is offline   Reply With Quote
Old 12-06-2010, 10:29 AM   #2
Rewards Points: 126
Ricardo, I have never heard of Andeli. But some contactors have a jumper that can be moved to select voltage. Sounds like you have 120 volts trying to operate a 230 volt coil. Check the jumper position. Can you measure the voltage to be sure?
Old 12-06-2010, 05:19 PM   #3
Something doesnt sound right. You said the circuit is 220v with a 110v contactor. Do you mean the contactor is switched with 110v or supplies 110v? If the old contactor was switched with 110v and is now being switched with 220v that might be your problem.
1982shawn is offline   Reply With Quote
Old 12-06-2010, 07:52 PM   #4
" Euro " electrician
frenchelectrican's Avatar
First thing first.,
What voltage are you running on the photocell??
What voltage are you try to supply the luminaires ??
What colour conductors you have in the contractor box and size of conductor.
Merci.
Marc
Issue with a definite purpose contactor and photo cell. bigmacfann Electrical 43 09-16-2011 03:56 PM
New cell phone trips GFCI Thurman Electrical 4 09-23-2010 09:49 AM
Pern value of 8 inches of open cell foam millertimeny Building & Construction 0 03-23-2010 11:28 AM
Closed Cell Spray Foam with Fiberglass? ddave23 Building & Construction 1 10-28-2009 01:54 PM
closed cell vs open cell foam insulation amonalisa Building & Construction 1 11-06-2008 09:39 PM
