Old 10-19-2008, 08:34 PM   #1
forgot a line to the baseboard heater!
Hey.. I goofed. I wanted to be sure ALL my electric lines were in before they blew in the cellulose into my country get-away (garage with "storage" up top). My plan is constantly evolving and I had some #12 and #10 wire to run. I ran 220 #12 for the two baseboards in the space upstairs from the garage.
I forgot to run the #12 to the baseboard in the temporary bathroom in the lower corner of the garage. I did run the #10 wire for the small 30 gal electric water heater in that bathroom/shower area.
The baseboard takes 8.5 AMPS. I hear water heaters take 15 to 20 AMPS. Can I run them BOTH off the same 25' long #10 wire?
If it's too much for that gauge of wire, what happens?
Thanks!
fauer is offline   Reply With Quote
Old 10-19-2008, 10:17 PM   #2
dSilanskas's Avatar
Thanks!
No you can't do that its to much for the breaker. Your baseboad teakes 8.5 amps you say probably on 220v and your need to find out what your water heater takes. even if it is 20 amps your still going to overload the breaker and cause it to trip. Your best bet is too try to fish a wire
dSilanskas is offline   Reply With Quote
Wiring a 220 Baseboard Heater joedadog Electrical 8 10-06-2008 07:17 PM
Leak on gas heater water line? darsunt Plumbing 3 04-16-2008 04:57 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
Baseboard Heater: Can I wire it to plug into an AC recepticle? JBiz Electrical 3 12-01-2007 09:42 AM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
