Foreman - Electrical - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 10:20 PM   #1
foreman
can i replace a 60 amp pushmatic bridge breaker with a 100 amp breaker to keep lower half of panel from losing power? the 60 amp trips too often.
ramonskilove1 is offline   Reply With Quote
Old 06-21-2011, 10:56 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
No!
The wire from the 60 amp breaker to the bottom of the panel is only rated for 60 amps.
You need to find out why it is tripping.
jbfan is online now   Reply With Quote
Old 06-21-2011, 11:07 PM   #3
Originally Posted by jbfan View Post
No!
I am lost, i changed the 60 with a 60 and it seemed ok but same problem with all the breakers, they seem to take turns tripping
Old 06-21-2011, 11:24 PM   #4
jbfan's Avatar
Rewards Points: 142
Do the breakers on the top of the panel trip, or is it the bottom breakers?
Does the new 60 amp breaker trip?
Old 06-21-2011, 11:27 PM   #5
mainly the 60 that feeds the bottom but that top ones trip as well.
Old 06-21-2011, 11:33 PM   #6
it is just so nuts, i dont know what to do.
Old 06-22-2011, 07:04 AM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
You need to call an electrician and have him check things out and see what is tripping and why.
What does "foreman" mean??
Old 06-22-2011, 09:52 AM   #8
joed's Avatar
Rewards Points: 11,576
You need to measure the amps to see if it is over current and breaker is doing its job. It is very likely the panel is over loaded and need to upgraded.
The Following User Says Thank You to joed For This Useful Post:
hpp58 (06-22-2011)
All heavy DIYers have done something dumb. Let's fess up. BJLower Safety 139 02-19-2015 03:26 AM
