Forced Air Furnace Fan Setting Won't Work - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-23-2011, 06:55 PM   #31
So, are we thinking that the white wire hooked up on the G of the stat will not turn on the fan then?
turkish777 is offline   Reply With Quote
Old 03-14-2012, 12:28 AM   #32
Rewards Points: 60
Furnace fan settings
Originally Posted by biggles View Post
go right to the fan motor wiring diagram on the motor fram see how many speed wires are showing heat is always LO or MED LO if you have HI speed wire that would be thru the stat from a relay in the furnace for cooling....the heat fan is controlled by that heat relay board....the stat has no control calling for fan your not wired.if you find a black HI speed wire and the white neutral coming from the motor i'll tell you how to control it with an add on relay that the stat can control
I have the same problem. Is there a chance you can give me an advise?
Sas007 is offline   Reply With Quote
Goodman GMP100-3 Forced air furnace sylvia HVAC 23 12-18-2011 09:49 AM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Forced Hot Air Oil Furnace Issues? Power Vent? marcomjl HVAC 1 11-25-2010 09:48 AM
GOODMAN 100-3 Forced Air Furnace problem lindatbird HVAC 4 11-10-2010 08:55 PM
Adding a stand alone wood furnace to existing duct work vtboy51 HVAC 1 04-01-2009 02:19 PM
