Force Air In Wall Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2012, 08:28 AM   #1
Force air in wall heater
I'm attempting to install a 240 volt in wall forced air heater , the wire use was 12/2. The 12/2 wire has a black, copper, and a white
The heater has a black , green ground , and a red,
What wires go together ?
Arashed36 is offline   Reply With Quote
Old 10-13-2012, 08:32 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
We could tell you pretty quickly, but I'm sure it tells you in the instructions.
Old 10-13-2012, 08:33 AM   #3
Wire a forced air heater
Forced air heater . What wires go together
Old 10-13-2012, 09:41 AM   #4
An old Tradesmen
Rewards Points: 6,914
The green wire is the ground same as the bare copper wire from your 12-2 is.
Blk to Blk, White to Red. Always nice if you mark the white wire with red tape of marker to indicate it is a current carrying wire.
PS: I merged your threads so all info is in one thread.
The Following User Says Thank You to beenthere For This Useful Post:
Arashed36 (10-13-2012)
Old 10-13-2012, 10:53 AM   #5
Master Electrician
Rewards Points: 3,824
What is the wattage of the heater?
brric is offline   Reply With Quote
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 12:26 PM
Need to attach B vent to wall heater Laneman HVAC 1 09-03-2012 05:34 PM
wall heater or baseboard? debiasio HVAC 1 02-08-2011 10:54 AM
Gas pipe to wall heater, can I just put a plug in it? diymonkey Plumbing 6 04-09-2009 06:30 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
