Food Disposal Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2009, 09:26 PM   #1
Rewards Points: 278
food disposal circuit
Currently I have a 20 AMP circuit for the disposal, a switch on the wall turns on a receptacle under the sink, the other plug of the same receptacle is for the dishwasher (another separate circuit), is this common practice?
Because I wanted one of those air switch on the counter, can I change the original switch on the wall to be a 20A receptacle, then continue to the dispsoal receptacle where the air switch unit is plugged in? There is no restriction I know of that says you cannot wire a food disposal downstream of a circuit or that the food disposal needs it dedicated circuit. The food disposal draws 8 amps only.
DIYGST is offline   Reply With Quote
Old 01-08-2009, 09:38 PM   #2
Electrician
Its not unheard of thats for sure.
Because I wanted one of those air switch on the counter, can I change the original switch on the wall to be a 20A receptacle, then continue to the disposal receptacle where the air switch unit is plugged in? There is no restriction I know of that says you cannot wire a food disposal downstream of a circuit or that the food disposal needs it dedicated circuit. The food disposal draws 8 amps only.
No, the receptacle on the kit counter would have to be considered a small appliance circuit at that point, and can only supply other receptacles in the kitchen or rooms specified in 210.52(B)(1).
What I would do is use one of your circuits for JUST the kitchen counter, and the other circuit for the disposal and DW, just as long as the DW does not draw more than 10 amps.
chris75 is offline   Reply With Quote
Old 01-08-2009, 09:57 PM   #3
Rewards Points: 278
Hi, I read the entry you listed in NEC
I assume the disposal is not considered a small appliance or not considered to be in the kitchen?
I do not want to plug the food disposal into the DW, because it is so much more likely I use both at the same time (hand wash pans while DW running) and the DW says it wants 12.5 Amps.
Old 01-08-2009, 10:03 PM   #4
Electrician
Correct
It would never trip the breaker, but...
The problem is that the DW is 12.5 amps, that would create a violation of 210.23 (A)(2), so best you can do is just leave the switch at the counter or blank it off.
Old 01-08-2009, 10:10 PM   #5
Rewards Points: 278
Thanks Chris I didn't know such restriction for disposal existed.
I am going to leave this thing alone but just replace the existing switch with a nicer one, can I get a heavy duty 20 AMP switch? It seems like the old style switch is safer than decora if you have "wet hands"
Old 01-08-2009, 10:14 PM   #6
Electrician
Its not a restriction for just a disposal but for Utilization Equipment fastened in place, You can still install the air switch, you just cant use the existing switch as a receptacle with the existing circuits at hand and still be code compliant.
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 07:59 PM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 08:09 PM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
