Foam Insulation - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2011, 07:17 AM   #1
Foam Insulation
I have a post Katrina modular home on a slab. It's over built and has solid foam insulation between the walls. I think they must of run the wire to the panel before putting the foam to it. My problem is: Whats the best method of getting a 10-3 UF through the foam to the panel. The panel is 14 inches wide (between studs) and all the romex and main power is coming into the top. There are spare knockouts on top but the holes coming in are full of wire. Has any body had this problem before? Help...suggestions.
Joe Willie is offline   Reply With Quote
Old 05-04-2011, 09:11 AM   #2
Rewards Points: 121
Joe, what you have basically is a SIP (structural insulated panel) wall. Do a google search on how to wire SIP's and you will find good tips on how to run wire inside of this type of wall. Good Luck.
jrepp44 is offline   Reply With Quote
Old 05-04-2011, 09:26 AM   #3
Thanks. It's spooky trying to put wire through foam that already has wires in it.
Canned Foam Insulation WindingRoad Building & Construction 5 01-02-2011 09:08 AM
Floor insulation, cellulose vs hard foam Arky217 Flooring 0 12-23-2010 10:44 PM
Foam Insulation turbomangt Roofing/Siding 13 11-02-2010 09:44 PM
conflicting spray foam insulation warnings yogi Building & Construction 8 10-01-2009 10:24 PM
Spray in foam insulation leted_82 Building & Construction 3 05-31-2007 10:14 AM
