Foam Board And Electrical Boxes - Electrical - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 03:37 PM   #1
Rewards Points: 722
Foam board and electrical boxes
I am curious, is it safe/legal/whatever to mount a metal electrical box directly to blue foam board?
Reason I ask is I am working on a box out in my kitchen that has a small shed style roof. In order to gain some R-value to the ceiling I am installing 1" blue foam board to the joists, then I'm going to cover the foam with drywall. The junction box for the light is a 4" diameter 1/2" thick shallow fixture metal box. In order to get the box flush with the drywall, I'm wanting to mount the box directly to the foam board, but I question if that is ok to do. The specs on the foam say protect from high heat.
I am wondering if instead of mounting the box to the foam, I need to go get a thicker box and cut the foam away and mount the thicker box directly to the 2x nailer I put in place to secure the box to.
Any suggestions?? Thanks!!
Master Brian is offline   Reply With Quote
Old 11-21-2010, 03:43 PM   #2
Rewards Points: 150
Nailer
ianc435 is offline   Reply With Quote
Old 11-21-2010, 03:55 PM   #3
I=E/R
a7ecorsair's Avatar
Heat won't be your problem. The box is supposed to be securely fastened to the building structure. Foam board isn't very durable for something like this and can easily rip out. You'd better get some solid backing behind it. Also, with foam board, how would you fasten the cable within 12" of the box?
a7ecorsair is offline   Reply With Quote
Old 11-21-2010, 03:59 PM   #4
Rewards Points: 722
I placed a 2"x6" between the joists to securely screw the box to. It's 1" thick foam, so as of now the box is secured with 2" long screws through the foam and into the 2x6 support. The wire is secured to that support.
Old 11-21-2010, 05:13 PM   #5
Rewards Points: 150
It'll work.
A thicker box is better.
You could also get a small 1"-thick block of wood and cut it into the foam...
emolatur is offline   Reply With Quote
Old 11-21-2010, 07:03 PM   #6
Rewards Points: 150
Originally Posted by emolatur
It'll work.
Put in the nailer and fill in after behind the box eith greatstuff expanding foam. Used minimupal expanding foam door and window.
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 10:50 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 09:41 PM
Particle board and electrical Outlet HELP!!! NikkiGagnon Electrical 8 01-18-2010 04:52 PM
How to mount outside light on metal garage stryped Electrical 12 09-29-2009 02:43 PM
code details for boxes kama Electrical 6 01-30-2009 10:25 AM
