Old 04-27-2011, 06:25 PM   #1
Jordan83
Send a message via AIM to jordan83 Send a message via MSN to jordan83
FMT wire install issue
I have a really dumb DIY question.
I recently did my basement and before doing that I had the last minute Idea to run a 3 ft peice of FMT from my laundry room into the closet on the 1st floor.
This of course is now hidden under my drywall ceiling but is accessible on both ends in the laundry room and and in the wall on the first floor. I ran wire already but did not run enough. I did not think about this enough and only ran enough for 1 circuit and I want to add more.
Is there anyway to add more wire to FMT without cutting the ceiling and pulling it out.
jordan83 is offline   Reply With Quote
Old 04-27-2011, 06:47 PM   #2
nap
You talking to me?
nap's Avatar
if you have access to both ends and you have room for the additional wire, I don't see why you would have a problem.
what kind and size of wire are you using and what size is the FMT?
Old 04-27-2011, 07:25 PM   #3
Jordan83
The FMT is 1/2 inch and hte wire is 12 gauge.
I thought there was some best practice about not running wires in existing FMT or was that BX ?
Old 04-27-2011, 08:01 PM   #4
Licensed electrician
The wires are pre-installed in what you called BX. Conductors are pulled into flexible metallic tubing after installation.
Old 04-27-2011, 10:21 PM   #5
nap
You talking to me?
nap's Avatar
Jim is correct.
Now, just to make sure, you do have a junction box on each end of this conduit, right?
and you did not say how many wires are already in the conduit and how many you want to add.
Old 06-01-2011, 05:42 PM   #6
Jordan83
There are 2 wires already in the FMT and I want to run at least 2 more possibly 4 is that that ok ?
Old 06-01-2011, 06:43 PM   #7
you can put up to 9 #12 THHN in 1/2" FMC
Techy is online now   Reply With Quote
The Following User Says Thank You to Techy For This Useful Post:
jordan83 (06-01-2011)
Adding a wall switch to a pull chain fixture abacuslearns Electrical 17 12-20-2011 07:02 PM
Can I pull my own wire and install outdoor coachlights on my garage? If so - how? Michael C. Electrical 2 12-20-2010 07:52 AM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
ceiling fan install with no red wire fabian Electrical 7 02-25-2009 07:47 AM
Wire shelving install red01baron General Discussion 6 02-20-2009 12:55 AM
