FMC Types? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 12:17 PM   #1
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
FMC types?
HI;
I'm putting in some recessed lights, and I think the Smurf I often used in non-exposed locations is a little bit inflexible for connecting the lights and is going to be difficult to work with.
I was thinking of trying some FMC for the lights. I remember watching a video here a member posted a couple weeks ago showing how flexible it was.
I look at the Flexible metal conduit at home depot briefly and it appeared that there were multiple types that all looked similar, some seemed more flexible than other, but all looked like the FMC.
Are there various types of FMC or is it made out of different materials? If so, which is the most flexible and easiest to work with?
I prefer just a conduit that I can push my own wires in.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 03-07-2009, 11:03 AM   #2
Rewards Points: 168
The trade name is "greenfield". Its an uncoated flexible metal conduit that you put your own wires in. I cannot vouch for the flexibility. It would be a good choice for lighting.
Or you could just go and get some MC cable at HD and be done with it.
Make sure you get the right fittings.
Old 03-07-2009, 12:21 PM   #3
Remodeling Contractor
There is aluminum and steel... or as posted others contain the wires and these are type AC or MC
Old 03-09-2009, 10:48 AM   #4
DIY'er
jamiedolan's Avatar
Thanks guys. I ended up picking up a roll of the MC style 12-2 with ground. I am going to use it for my light fixtures. I feel alot better about using it than I do about just plain old romex.
Thanks again
Jamie
Old 03-09-2009, 01:37 PM   #5
Before I pulled all of that romex I should have considered mc...oh well.
rgsgww is offline   Reply With Quote
Old 03-09-2009, 02:44 PM   #6
Thanks again
Jamie
Did you have a bad experience with NM as a kid?
jerryh3 is offline   Reply With Quote
Old 03-10-2009, 09:39 AM   #7
DIY'er
jamiedolan's Avatar
Yea, but not when I was a kid, Just back in January. I watched the Romex at my parents melt and almost start the house on fire.
I did get to also see what happened to the wires in the conduit (EMT) they were destroyed, but there was no molten plastic dripping everywhere, it all staying in the conduit, and the conduit was unharmed.
So yes, an irrational fear of romex perhaps. Honestly, even considering my romex avoidance, I have still used a bit of romex here and there in my own house. I just feel better overall with something more substantial. (EMT, or ENT and now some MC).
Jamie
Old 03-10-2009, 10:20 AM   #8
What was the cause of the melting?
Old 03-10-2009, 11:13 AM   #9
If I remeber correctly, a ground shorted to the unfused SE conductor and traveled through the romex grounds to get to ground. I think they had to have the poco cut power at the x-former cutout.
I may be wrong how the story went...
Old 03-10-2009, 11:23 AM   #10
I guess that will do it.
Old 03-11-2009, 01:50 AM   #11
DIY'er
jamiedolan's Avatar
Close. He shorted the 4awg to the water meter. The increadiable heat generated melted the insulation on all the cables in the panel and several piece of romex new the panel along with THHN in emt melted down, presumably from the transfer of heat. It smelled horriable in there. Burning wire smell.
Jamie
P.S. Forgot to mention a bad experience with Romex and a flex drill bit and my hand caught in the middle of the wire while the drill was winding it up at full speed.....
What types of wood is used in your area? bluefitness Building & Construction 7 12-21-2008 10:16 PM
Code question regarding AFCI combination types and the 2005 NEC MattOverMinder Electrical 2 12-14-2007 03:10 PM
Types of Earwigs and features of Earwigs Pholma Pris Pest Control 4 11-20-2007 05:19 PM
