Fluorescent Tube To Wall Socket? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2012, 09:08 AM   #1
Fluorescent tube to wall socket?
Hi,
I'd like to connect a fluorescent tube to a wall socket. Is it possible? Of course, it'd be one with a ballast and I just want to know if anyone has a guide how to wire the wires from the ballast to a wall plug and if it's that simple? Thanks!
monkchild is offline   Reply With Quote
Old 05-20-2012, 09:25 AM   #2
Rewards Points: 1,512
The ballast should have instructions for where to hook up the power from the plug.
The ballast might have different terminals for different input voltages (120 volts, 277 volts, etc). Be sure you choose the proper terminals.
Note that build-it-yourself light fixtures are not safety rated by organizations such as Underwriters Laboratories even if you used components are are so rated.
Old 05-20-2012, 09:30 AM   #3
MarginallyQualified
Rewards Points: 2,464
Just buy an already assembled light fixture.
A two tube $10 shop light comes with a cord as well.
btw... how big will your grow be?
Old 05-20-2012, 09:40 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,818
Yea.....make sure you use the right color bulb.....and don't put too many in.....the power company will notify the police if a house is using an unusual amount of electricty....
ddawg16 is online now   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Can I remove this wall? limited60 Remodeling 9 06-05-2012 01:32 AM
Building a half wall: 2 questions kbizzle Carpentry 7 02-19-2011 08:22 AM
Wall Socket Rewiring Question bravoxena Electrical 9 07-25-2010 06:17 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
