Fluorescent Tube Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 10-30-2011, 10:47 AM   #1
fluorescent tube lighting
Parents have a 2 bulb fluorescent tube light (48" long bulbs - 2 pins on the ends) in their kitchen. If you stand under the fixture the tube on the right is out and the tube on the left is just barely glowing, replaced both sides with new bulbs with the same results. Bad starter or bad ballast
schaf13 is offline   Reply With Quote
Old 10-30-2011, 10:57 AM   #2
Sparky
Rewards Points: 510
likely ballast.
may not even have a starter, i would replace both if it actually has a starter
Techy is offline   Reply With Quote
Old 10-30-2011, 11:33 AM   #3
Licensed electrician
Rewards Points: 1,022
Are the bulbs the proper ones for the ballast?
Old 10-30-2011, 06:35 PM   #4
seansy59's Avatar
Rewards Points: 258
This indicates a rapid start T12 magnetic ballast. Old one that works in series (one goes out, they both do). Make sure the bulbs are seated properly. If this doesn't work, then you probably need a new ballast.
seansy59 is offline   Reply With Quote
Old 10-31-2011, 01:16 PM   #5
Rewards Points: 58
Ballast will cost more than fixture. Need new fixture.
Old 11-01-2011, 10:11 AM   #6
It was a T12 magnetic ballast (had no starter) By the time priced a new ballest and new tube mounting clips on the end of the light as noticed all 4 were broke I bought a new light. Thanks to all that responded to this question as all answers were helpfull
replacing fluorescent tube light with regular bulbs nikeman Electrical 7 08-07-2011 09:33 PM
Help changing fluorescent lighting in Bathroom and Kitchen boomsday Electrical 8 11-20-2009 08:36 PM
4 tube fluorescent fixture with two bulbs? dyeager535 Electrical 2 02-02-2009 06:51 PM
Recessed Fluorescent Lighting - how many bakerhouse Remodeling 2 05-13-2008 11:42 PM
Installing new lighting on knob and tube wiring drichard Electrical 1 03-05-2006 03:55 PM
