Fluorescent Lights Will Not Work - Electrical - DIY Chatroom Home Improvement Forum
Old 07-24-2009, 11:06 AM   #1
My house is almost 6 years old and I have a fluorescent light fixture(T12, 2 tubes, 48 inches) in my garage ceiling that recently will not work. I thought maybe the fluorescent lights needed changing and so I replaced them. It worked for a a day or two and now it doesn't work at all. After replacing the old tubes and I first turned the switch on, I could see a small dimmer of light that flicked on at the end of the tube but now it doesn't do it at all. Is it the ballast? the starter? should I replace the whole unit?
g8tkeeper is offline   Reply With Quote
Old 07-24-2009, 11:11 AM   #2
Make sure the bulb is seated properly. Some bulbs have an index mark on the metal end.
If they worked once I assume the fixture is grounded.
It sounds like you should try new starters. You may need a new ballast but a whole new fixture sometimes costs the same [but the new fixture may ask for 90C wire and you may have 60C wire].
I guess there is some remote chance it is the sockets [the tombstones] but checking this is difficult.
Old 07-24-2009, 11:43 AM   #3
Rewards Points: 126
Sounds like the bulbs are not seated correctly in the tombstones (bulb holders). A new ballast will cost more than a new fixture. That may be your only recourse. Replace it.
Old 07-30-2009, 12:11 PM   #4
This happened to me- same fixture, same location. Try cleaning the bulb's contacts and reinstalling/ reseating them. Apparently the humidity (in my case) had something to do with the problem.
Johnnoh is offline   Reply With Quote
Old 07-30-2009, 02:10 PM   #5
FLOURESCENT TROUBLESHOOTING
-blinking or dim: cold drafts hitting lamp
-dim: dirty bulb
-slow starting in high humidity: dirty lamps or low supply voltage
-short lamp or starter or ballast life, lamp won't start: miswired ballast (for a two lamp fixture, both ends of the same lamp must glow when you short the starter connections).
Old 07-30-2009, 02:17 PM   #6
1. Replace lamps, make sure they are seated properly.
2. Test power.
3. Check tombstone wires (plugged into the back)
4. Replace ballast or fixture.
220/221 is offline   Reply With Quote
jenn-air cooktop electric pilot lights do not work puckmen Appliances 1 07-27-2009 08:29 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 09:55 AM
Hall lights don't work. jagrunner2602 Electrical 13 05-02-2007 11:08 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 05:02 PM
