Fluorescent Lights In The Garage Do Not All Turn On - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 09:21 PM   #1
Rewards Points: 590
Fluorescent lights in the garage do not all turn on
Have 3, 2-bulb fluorescent light fixtures in the garage, standard stuff.
When I hit the switch, sometimes only a random 1 comes on, sometimes random 2, and sometimes all 3. Eventually, they will all come on at some point.
Does this just mean they need new bulbs? When they are on, they all switch on nice and bright.
Thanks....
noone is offline   Reply With Quote
Old 06-30-2011, 09:38 PM   #2
Electrical Contractor
kbsparky's Avatar
High humidity and dirty/dusty bulbs can cause this....
-KB
Old 06-30-2011, 10:08 PM   #3
Rewards Points: 590
In Florida. On marsh. How do I fix it? Just clean the bulbs?
Old 06-30-2011, 10:43 PM   #4
Rewards Points: 6,652
How corroded are the contacts on the "tombstones" (ie the plastic pieces on the end of the fixture that look like tombstones).
Old 06-30-2011, 10:54 PM   #5
It may also be you ballist/ballists
I repair many florescent fixtures that were doing what you mention.
If cleaning or rrplaceing bulbs don't work, replace ballistic. Or it may even cheaper to by new lights.???
Shop around first.
Sent from my ANDROID DEVICE using DIY Chatroom
STEVEEBY is offline   Reply With Quote
Old 07-01-2011, 12:08 PM   #6
Rewards Points: 590
In my basement, I have fixtures with pairs of T12s are probably rapid-start. I had one that would not start consistently, so the easiest thing to try was to replace a tube (I tried the one that was older based on the amount of darkening on the ends) and it fixed the problem.
Last edited by operagost; 07-01-2011 at 12:32 PM. Reason: Gave wrong size for tubes
operagost is offline   Reply With Quote
Old 07-01-2011, 01:18 PM   #7
Licensed Pro
Dirty contacts, bad ballast, poor or missing ground
Old 07-01-2011, 05:24 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,354
How old are the fittings ?
The older type floro fittings that used the larger diameter tubes,
used to run on a slightly lower voltage than the newer type
quick start tubes.
So if it was designed for the older tubes,
the newer tube might not work correcttly,
or possibbly work slower or sluggish.
You might be better off to replace the fittings !
Or find some of the older style tubes.
dmxtothemax is offline   Reply With Quote
Old 07-01-2011, 09:51 PM   #9
Rewards Points: 590
How was built in 1996.
Changed all six bulbs and everything works great. The tips of the bulbs were corroded. For some reason, i thought it would be more than that, but im glad it was not. Thanks for the suggestions.
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 08:20 PM
Adding lights on the same circuit as garage door opener russ960 Electrical 11 02-23-2011 07:48 AM
Wiring new lights in garage Question Tyus4 Electrical 92 02-13-2011 11:46 PM
Turn a basement into a garage pls2pgh Remodeling 2 10-03-2006 05:44 PM
