Fluorescent Lights... AAAAGGGGHHH! - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2012, 04:04 PM   #1
Question
Fluorescent lights... AAAAGGGGHHH!
Ok so i ditched the idea of the other lights and broke down and went to lowes and bought 8 ft tandem lights/4bulb ... t8. the ballast says they are 120v-277v. I have a wire tester and have checked and i have power to all the lights but they wont come on! AAAGH! any ideas? Is there something i have missed?
lilcricket350 is offline   Reply With Quote
Old 08-03-2012, 04:10 PM   #2
Licensed electrician
Rewards Points: 1,622
Could you tell us how you made the connections?
Old 08-03-2012, 04:12 PM   #3
biggles's Avatar
make sure your connected to the 120v wires as the ballast says...if OK then the bulbs aren't touching the metal pins they go in with the pins straight up. then push them in and turn them1/4 turn so the pins are sideways all lenghts must be in to make the circuit
Old 08-03-2012, 04:49 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,354
What did you use to test for power ?
You could have a problem with your neutral line !
Especially if you used a non contact tester !
dmxtothemax is online now   Reply With Quote
Old 08-03-2012, 06:33 PM   #5
Rewards Points: 266
You must have good ground to the luminaire to strike a fluorescent lamp.
http://nemesis.lonestar.org/referenc...t/trouble.html
http://assets.sylvania.com/assetlook...ting%20Systems
ionized is offline   Reply With Quote
Fluorescent lights ozbuc Electrical 4 01-24-2012 02:41 PM
Fluorescent lights don't seem to last preciouschristy Electrical 20 01-10-2012 08:47 AM
Kitchen fluorescent to LED recessed lighting changeout speedytahiti Electrical 1 01-05-2012 07:04 PM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 08:25 PM
