Old 01-24-2012, 11:34 AM   #1
Fluorescent lights
Hello from a new member. I had a fluorescent light go out on me. It was a 25 watt light. The hardware store only had 34 watt. These did not work. Would the problem be the difference in the wattage or could it be the ballast/starter? Thanks in advance for any and all help.
ozbuc is offline   Reply With Quote
Old 01-24-2012, 11:49 AM   #2
Julius793's Avatar
Fluorescent lights
What's the ballast rated for? Are they the same size bulbs?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-24-2012, 03:34 PM   #3
Fluorescent lights
Thanks for the reply. Both the old and new lamps are 48". I don't know what the ballast is rated for. I looked but could not find the ballast.
Old 01-24-2012, 03:38 PM   #4
Julius793's Avatar
Fluorescent lights
When I asked size I didn't mean length I was talking about t-12,t-8. Anyway i would say you will probably need new ballast but if you can't find it... I think you will be better off getting an electrician.
Old 01-24-2012, 03:41 PM   #5
Fluorescent lights
Again thanks for the response and sorry for the confusion. Both old and new lamps are T12.
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 01:35 PM
trying to replace fluorescent lights with newer lighting tech MLMIB Electrical 5 10-16-2011 02:50 PM
Fluorescent lights multiple carpenterty Electrical 13 12-04-2010 12:26 AM
Fluorescent Lights Will Not Work g8tkeeper Electrical 5 07-30-2009 03:17 PM
How to switch fluorescent lights Carissa Electrical 3 08-16-2008 03:28 PM
