hello all
i have a question
i'm starting up my fish house again and i want to keep most of the electrics outside as its a wet room
(last time i had less but bigger tanks so it wasn't as big an issue)
i want to locate all the control gear outside the room and just have the arcadia leads with the waterproof encaps inside connected to the tubes.
those are designed for use with aquariums
this is what i mean
http://www.aquatics-online.co.uk/add...tp=52&rets=205
i was hoping to wire those up using this type of control gear
http://www.tlc-direct.co.uk/Main_Ind...l_1/index.html
ideally i was hoping to operate several tubes with one of those
if i could wire 4 into the 120 watt unit that would be fantastic
i have 8 tubes that need connecting and
each one is 36" 30 watt
i really hope someone can help me out with a wiring diagram
i know i need a starter to ignite the gas in the tubes but not sure if i could get a fitting for one?
so what i need is a good selfexplanatory wiring diagram and maybe a few good link on where to buy stuff needed
i want all the electrics savely away in a small cupboard, ideally something in the size of a small bathroom cabinet
my fish house or room is half of my garage so nothing will be outside in the weather as most fish houses or sheds are located at the bottom of the garden
thanx for your help and advise
