Fluorescent Light Sockets - Electrical - DIY Chatroom Home Improvement Forum
Old 09-03-2011, 10:55 AM   #1
Fluorescent Light sockets
What is the difference between a shunted and non shunted socket?
tcourson is offline   Reply With Quote
Old 09-03-2011, 11:00 AM   #2
seansy59's Avatar
Rewards Points: 258
Shunted is for instant start ballasts. The wires go to both sides of the pins on the tube.
Non shunted is usually for rapid start ballasts. The pins are seperated inside the socket. And wires go to seperate sides.
Shunted:
________
__|____|__
Non-Shunted
_|____|__
seansy59 is offline   Reply With Quote
Old 09-03-2011, 09:25 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Also becarefull some of the tombstone they are shunted interally from factory they will have " S " marking on them if you have doubt just ring it out with ohmmeter to make sure.
Majorty of new luminaire with electroinic ballast genrally have shunted tombstone if wired up for instat start mode for rapid start mode it will not be shunted.
the quick way you can tell if rapid start or instat start is take out one flourscent bulb if other bulb go out then you have rapid start if not then more likey you have instat start { few case you may ran into bad rapid start ballast will act like instat start due the interal coil inside the ballast is shorted out }
Merci,
Marc
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
replacing fluorescent tube light with regular bulbs nikeman Electrical 7 08-07-2011 08:33 PM
Basic light wiring question speedster1 Electrical 3 11-29-2010 06:48 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
Condensation in overhead light JB Toyz Electrical 0 12-06-2009 02:40 PM
