Fluorescent Light Flickers Even When Off - Electrical - DIY Chatroom Home Improvement Forum
Old 01-27-2013, 03:41 PM   #1
Rewards Points: 85
Hey everyone. Hope all is well.. My question has to do with a draw string 24" T8 light I installed in the bedroom closet....
The other night laying in bed I noticed a quick flash of light coming from the closet. I saw it again and sure enough it was coming from the fluorescent light I installed a few weeks ago. This light is on a circuit which feeds the bedroom lights. It's a 20A feed. The house was built in 1936 and if anyone remembers my last post, I wrote about getting a little jolt on the common when the breaker was off while installing this same branch. A logical reply was the common was shared with another circuit and was typical of older homes. I just replaced the fixture and to my surprise the new one flickers as well... What could be causing this??? When the breaker was off I checked the common and it was dead this time.
I guess the big question is can this be hazardous? A fire risk?
Thanks!!
JohnC20 is offline   Reply With Quote
Old 01-27-2013, 04:22 PM   #2
Rewards Points: 1,538
Is the wall switch for this light illuminated? The electricity used to light up a switch toggle goes through the load (light) controlled by the switch and can cause a fluorescent light to glow or flash.
Old 01-27-2013, 05:00 PM   #3
Rewards Points: 85
Holy crap!!! On the same circuit there is the attic light on a illuminated switch...
Why would that cause it to flash??
Old 01-27-2013, 06:05 PM   #4
joed's Avatar
Rewards Points: 13,348
The wall switch for another light should not cause this. Is the attic light a lighted switch or a switch with a pilot light that comes on when the light is on? A lighted switch comes on when the switch is turned OFF.
Old 01-27-2013, 06:15 PM   #5
Did you make sure that your neutrals are tight?
mbryan is offline   Reply With Quote
Old 01-27-2013, 06:44 PM   #6
Rewards Points: 85
The attic switch is lighted when the switch is off. It doesn't control the fluorescent light I am talking about, but it's on the same circuit.
Old 01-27-2013, 06:45 PM   #7
Rewards Points: 85
I haven't gone back up in the attic to check the other neutrals but the one on the light are tight with elect tape around the wire nuts.
Old 01-27-2013, 07:03 PM   #8
Rewards Points: 85
Please keep in mind, this is happening when the switch is off...
Old 01-27-2013, 07:47 PM   #9
The light flickers when it's off?
Old 01-27-2013, 07:56 PM   #10
Rewards Points: 85
Yes! That's what's odd. The switch is a draw string type on the light fixture and when it is off, there's a quick pulse or flash on the bulb every minute or two. The bulb doesn't go full illumination, just a quick flash that maybe half the bulb lights up. It happens now on the replacement fixture so it's gotta be the wiring IMHO...
Old 01-27-2013, 09:59 PM   #11
Then I have got nothing...
Old 01-28-2013, 05:56 AM   #12
Rewards Points: 85
Yeah! Me neither.. Gonna check connections to see if any are loose.
Old 01-28-2013, 07:44 AM   #13
joed's Avatar
I suspect the wiring is fine. Problem is probably with the way the fixture is designed.
Old 01-28-2013, 08:00 AM   #14
Rewards Points: 85
But it is happening on the replacement as well!! The first one was flashing, replaced that with a new one and now that one flashes!!!!
Old 01-28-2013, 11:31 AM   #15
joed's Avatar
Without seeing how it is wired internally I can't say anything more that would be useful. I don't know how it could be mis wired that would make it flash when it has its own internal switch.
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
replacing fluorescent tube light with regular bulbs nikeman Electrical 7 08-07-2011 08:33 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
direct wiring fluorescent light amakarevic Electrical 7 01-11-2010 09:03 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
