Fluorescent Light And Clock - Electrical - DIY Chatroom Home Improvement Forum
Old 08-08-2012, 07:12 AM   #1
fluorescent light and clock
I have an old advertisement clock with a circleline fluor. tube. It seems to be wired properly but blows the tube as soon as it's plugged in . I was wondering if the configuration on the 4 prong plug should be in any specific order. Thnx
drm4973 is offline   Reply With Quote
Old 08-08-2012, 07:18 AM   #2
joed's Avatar
Rewards Points: 12,922
What voltage is required? If it is a commercial sign it could be one of many different voltages. A four prong plug is not normal. It could be a part of a display item (top of a cooler for example)and the ballast was in the other half.
Old 08-08-2012, 07:41 AM   #3
Thnx for the response. It's a wall mtd clock , only 120v. with a 22watt circle fluor. tube.
Old 08-08-2012, 09:01 AM   #4
Rewards Points: 758
A 4 pin connector is standard for the Circline lamps.
It may be a bad ballast. Can you follow the harness to find the ballast?
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
drm4973 (08-22-2012)
Old 08-22-2012, 06:40 AM   #5
thanks
yeah turns out it was the ballast , thnx
Stopping the Light Switch from Controlling Socket theshiv Electrical 9 01-13-2012 12:12 PM
Turning OFF light switch causes AM radio interference ? gcmackinnon Electrical 4 10-19-2011 12:03 PM
Light inside microwave dakotadog Electrical 5 01-11-2010 06:10 PM
Fluorescent Clock Rewiring pjtessy Electrical 4 01-04-2009 09:45 AM
Overhead light w/ switch and 3 recept. how to wire? twilightcall Electrical 8 01-07-2008 04:27 PM
