#1 |
Fluorescent Light Ballast
Hi, I'm from Canada (eh). I want to install a fluorescent light fixture http://www.homedepot.ca/webapp/wcs/s...k=P_PartNumber I want to connect it to a light-switch that controls power to an electrical wall outlet. Is this possible? Cheers.
#2 |
1. The power feed with neutral for the receptacle must first enter the existing switch box in question and then you add a cable going up to your new light. Note that you will have to choose one of:
1a. Have the switch control both the new light and the receptacle. 1b. Change the receptacle wiring to always-on and use the switch for the new light, 1c. Install a duplex switch unit. Alternative: 2. You run a power feed going to your light and then you can run a cable down to the existing switch box. You still have to make a choice, 2a. Install a duplex switch unit, 2b. Change the receptacle wiring to always-on and use the switch for the new light.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. |
#3 | |
Fluorescent Light BallastQuote:
Or, I think that you might be able to remove the outlet from the box, and then install a new fixture over the box and run the wires through a knock out on the fixture if you want it hard wired. (Depending of course that the position of the outlet is where you'd like your light fixture to be centered.) But you might want to look into that, I'm not an electrician and I am sure I'll get hammered for that. |
#4 |
Sorry, I see now that you wrote "wall" outlet, I was thinking the outlet was on the ceiling.
Good advice has already been given. If it were me I would run new cable from the switch, and then it's up to you if you want to do a little rewiring to make the outlet "always on" or you can leave it to be controlled by the switch if you don't use it much. Just make sure your existing switch box has the capacity for the new wires. |
#5 |
It was a dark and stormy
If it's not grounded it may not always "start", it's something about capacitance from the metal shell to the tubes 1/2" away.
I'd scrape the paint away from the grounding screw. |
#6 |
Be careful about the box fill. Assuming a metal box:
Table 314.16(A) of the 2005 NEC dictates the number of conductors you are allowed. You will certainly need a deep (probably 75x50x70mm) box to meet this requirement. Also, if your branch circuit is 20A, with #12 AWG wire, your new wiring to the light will also have to be #12, and you fill up the box really fast. If you have NM cable running into the box, and you are permitted to use nonmetallic outlet boxes, I think you could get more conductors in that than in a metallic one. I don't see a chart in the 2005 NEC for nonmetallic box fill.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by KE2KB; 12-20-2008 at 05:00 PM. |
#7 |
I think you mis-placed this post. Unless I'm missing something here
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#8 | |
DIY'er
Jamie
Jamie Dolan - Neenah, WI To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Need Help Uploading Photos? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. . |
#9 |
Fluorescent Light Ballast |
#10 |
Sorry about that.
#11 | |
I never realized that fluorescent light fixtures needed to have their framework grounded to work properly; I would have guessed at first that a defect existed. Now if the fixture relies on capacitance to ground, doesn't that imply leakage and a GFCI would trip?
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. Last edited by AllanJ; 12-20-2008 at 07:54 PM. |
#12 | |
My License Ain't 4 Sale..
#13 | |
You could assume a parallel plate capacitor and use the "8.85 formula" in this link http://en.wikipedia.org/wiki/Capacitance and convert all distances to meters. You need .09µF at 60 Hz and 120v to trip a GFI. I'd think there'd be way more capacitance from the primary winding to the grounded metal ballast case. Electronic ballasts without large windings may have much less capacitance to ground unless they put in an RFI filter. |
#14 |
This discussion reminds me of a time when one of my flourescent lights in my unheated garage wouldn't work in the winter! It turned out to be a bad ground! Worked OK in the summer though! Must have been because of the capacitance wasn't suitable to ionize the lamp gas!
#15 | |
| Display Modes | |
| fluorescent light wiring | "B" | Electrical | 1 | 12-28-2007 10:54 PM |
| Switching to CFL (Compact Fluorescent light) | Dragon | Electrical | 3 | 06-30-2007 12:08 PM |
| Fluorescent light ballast | billinak | Electrical | 5 | 03-02-2007 06:41 PM |
| Noisy, humming fluorescent light | Unregistered | Electrical | 1 | 11-14-2004 04:28 AM |
