Fluorescent Lamps No Balast Instalation - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2012, 09:35 AM   #1
Fluorescent lamps no balast instalation
Is there a way to install fluorecent lamp without balast
JOSE GUILLERMO is offline   Reply With Quote
Old 12-23-2012, 09:56 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Yes...you can install tube type lamps without a ballast...but they won't light.
You can install CFL type lamps in a regular socket and they will work because the ballast is integral to the lamp.
Old 12-23-2012, 10:16 AM   #3
Rewards Points: 1,192
Some L.E.D. lamps are 120 voltage.
bobelectric is offline   Reply With Quote
Old 12-23-2012, 04:25 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,190
NO !
you cannot use a regular floro tube with out a ballast !
It is needed for 2 x reasons.
1 - start up the tube.
2 - regulate currant thru tube once started.
So no ballast = no start.
If for some miracule it did start,
it would quickly burn out with out
ballast to regulate currant.
dmxtothemax is online now   Reply With Quote
Old 12-23-2012, 04:26 PM   #5
NO !
Foray to the green side- LED lamps rjniles General DIY Discussions 2 04-05-2012 09:49 PM
T12 to T8 fluorescent conversion? rjniles Electrical 28 08-18-2011 08:39 AM
No ballast in 48 inch fluorescent fixture. Timster Electrical 16 06-10-2010 04:02 AM
Attractive yet functional lamps for a house with small children? ChrisT Interior Decorating 6 09-25-2008 07:09 PM
electric wiring for fluorescent lamp toronbolo Electrical 3 03-24-2008 12:16 PM
