Old 09-03-2008, 03:37 PM   #1
Unhappy
Fluorescent lamp requires wall switch to be cycled several times before lighting.
I have a ceiling fixture with two 48in. flourescent lamps and a ballast. The fixture requires the wall switch to be cycled on and off several times (as many as 10 times) before the lamps will light. It appears that the lamps are trying to light, as I can see faint light at the ends of one of the tubes. Actually, this fixture is the second one I installed, as I had the same problem with the first one, and thought it was the fixture). Could I have an electrical problem with the wall switch or the wiring? Appreciate any ideas.
joejean is offline   Reply With Quote
Old 09-03-2008, 04:18 PM   #2
Licensed Pro
First thing to check is if the fixture is properly grounded. An improper or no ground will give the symptoms you describe.
Old 09-03-2008, 05:00 PM   #3
Thanks, I'll check that first.
Old 09-03-2008, 05:27 PM   #4
J Calvin Construction
jcalvin's Avatar
Next, Check Bulbs. one bad bulb will make them both go out unless you have an electronic balast
Then, Check to see if you have a bad starter. If it has one, it will be about .5inch round and 2inches long
Finally, Throw it away and buy a new because it is probably your ballast and they are as expensive as the light is
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 09-03-2008, 11:42 PM   #5
Electrician
SD515's Avatar
The switch might be 'old and worn'...it's usually in the wiring connections, ground, or the light fixture...but sometimes the switch is worn and not making a good contact.
Old 09-04-2008, 09:48 AM   #6
Power Gen/RS Engineer
If you simply turn on the switch and leave it on, what happens. Does the fixture eventually light?
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
recessed lighting wiring to 3way switch DIY4EVER Electrical 1 07-12-2007 02:35 PM
ceiling fixture with on-off wall switch carlu Electrical 1 03-04-2005 09:13 AM
Wall Switch sue Electrical 4 02-06-2005 08:05 PM
