Fluorescent & HPS Fixtures On Same Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 03-01-2010, 06:02 PM   #1
Fluorescent & HPS fixtures on same circuit
Can fluorescent fixtures (2 lamp 32w T8) and 150 watt single lamp HPS fixtures share the same circuit? Any issues with harmonics? Both types are 120 volts.
Thank you,
Mike
Mike2401 is offline   Reply With Quote
Old 03-01-2010, 07:01 PM   #2
Electrical Contractor
kbsparky's Avatar
1) yes
2) possible, but only on wye connected 3 phase systems ... but irrelevant whether they share the circuit or not
-KB
Old 03-01-2010, 07:55 PM   #3
Thank you KB.
Genuinely appreciate your prompt response.
Mike
Old 03-01-2010, 10:18 PM   #4
" Euro " electrician
frenchelectrican's Avatar
To answer your first question yes it done very often as long the total load do not excessed the circuit conductor size requirement.
Second question it only affect on triphase supply not affet with single phase supply { unless you got serious unbalanced load }
Merci,Marc
Old 03-02-2010, 02:30 PM   #5
Thank you Marc!!!
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 07:09 AM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 07:46 PM
Wiring a single pole switch into a 220v circuit rlmorgan Electrical 38 10-15-2008 08:59 PM
Tandem Fluorescent circuit Unregistered Electrical 4 11-16-2004 11:17 PM
