Fluorescent Fixture Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 05-17-2008, 10:26 PM   #1
Fluorescent fixture not working
Hello all. My fluorescent fixture in the kitchen does not work. It fails to start every time everytime it is turned off for some time. I have to play with the on/off switch rapidly until it turns on. If the light is on and I turn it off and then back on, it turns on just fine. I looked at the bulbs and really did not see any problems with them. Well actually one looks like the begining stages of dying since a black light round ring is begining to form. Could it be the bulb, light switch, ballast? Any help or info appreciated. Thanks
Hector
hgiljr is offline   Reply With Quote
Old 05-18-2008, 09:44 AM   #2
joed's Avatar
Rewards Points: 12,440
Change the bulbs. You can't tell by looking if they are bad.
Old 05-19-2008, 12:14 PM   #3
Rewards Points: 89
Well, luckily with Fluorescent fixtures, there isn't too much to check. You can replace the bulbs and see if that resolves it, but sounds like it may be the starter (also cheap to replace). You can twist out the old one, take to the store, match up and replace.
mahjohn is offline   Reply With Quote
Old 05-19-2008, 03:22 PM   #4
Registered User
Termite's Avatar
Sounds like the starter to me!
Old 05-19-2008, 07:59 PM   #5
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
I'm going to pile on. Replace the starter.
John
jrclen is offline   Reply With Quote
Old 05-20-2008, 11:54 PM   #6
I'm not going to pile on, because if it's a "rapid start" ballast, there is no starter.
Here's how you can tell the difference: rapid start ballasts will emit some light the instant the switch is on turned on, but will "flicker" their way to being fully on within about one second. Ballasts that rely on a starter won't light up right away; they will remain dark for a second or two, then "pop" on, sometimes flickering rapidly off and on once or twice before staying lit. Starters also sometimes make a distinct "tink, ka tink" sound as they start the lamp, while rapid start ballasts are relatively silent as a rule. (Except for the occasional 60 Hz humming noise.)
If you think you have a "rapid start" ballast, replace the bulbs. If there are two bulbs, replace them both; if one is dying, the other will be close behind, as they run in series. Take the old bulbs in with you to make sure you get the exact replacement, and for recycling/hazardous waste disposal. Many stores (such as my local Ace Hardware) will accept the old ones for disposal free of charge upon purchase of new ones.
If new bulbs don't fix it (and they probably will), then replace the ballast (again, bring the old one to the store for an exact replacement and for disposal).
thegonagle is offline   Reply With Quote
Old 05-25-2008, 11:20 AM   #7
Rewards Points: 128
I would check the switch too. He did say he had to play with it, to get the lights to work. Thats were I would start. Jump out switch and see.
A faulty bulb or a faulty fixture? don54 Electrical 5 12-25-2007 04:38 PM
Kitchen light fixture stopped working dlpcpa Electrical 4 12-17-2007 07:46 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 05:25 PM
Help, new fixture not working Christine Electrical 3 01-17-2007 06:24 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
