Fluorescent Fixture - Convert From T12 To T8 - Electrical - DIY Chatroom Home Improvement Forum
Old 10-20-2010, 04:40 PM   #1
Fluorescent Fixture - Convert from T12 to T8
Hi,
I have a few 4' two-tube fluorescent fixtures in the garage. They plug into 120v outlets. Currently, they have GE Cool White T12 tubes in them.
Someone gave me a case of Sylvania OctronŽ 700 Ecologic T8 tubes that I would like to use.
http://www.1000bulbs.com/product/6428/F-32T8765S.html
I want to use the new, free tubes in the fixtures I have, so I am looking for info on replacement ballasts, e.g. which ones, where to buy, how much to pay, and any other advice.
Thanks in advance!
sbdivemaster is offline   Reply With Quote
Old 10-20-2010, 06:11 PM   #2
Licensed electrician
Rewards Points: 1,794
You would buy a ballast for the correct voltage and number and type of tubes.
You might find it just as economical to just buy new fixtures compared to the price of the ballast.
Old 10-20-2010, 07:05 PM   #3
Rewards Points: 1,542
If the voltage and wattage (usually stamped on the glass at one end) is the same and the tube fits in the socket (one pin or two pins) then just substitute one for another.
The designations T8, T12, etc. refer to the physical size of the tube, here, the diameter.
Old 10-20-2010, 08:31 PM   #4
The newer T8 tubes have a reduced wattage vs the T12 tubes. Most T8s are 32 or 34w while the older T12s used to be 40w.
Old 10-21-2010, 07:58 AM   #5
joed's Avatar
Rewards Points: 13,368
Most T12 are also 35w now. You can't just swap the tube types. You need to change the ballast. The question is too broad. It kind of like asking what tires should I put on my car. There are too many brands etc. Go to a supply house and tell them you need a 120 volt two tube T8 ballast for 4 foot tubes.
hardwire a pre wired, plug in fluorescent fixture...? inlovewithohio Electrical 3 12-01-2010 11:10 AM
Wiring fluorescent fixture to ceiling box Richo Electrical 12 08-05-2010 06:19 PM
No ballast in 48 inch fluorescent fixture. Timster Electrical 16 06-10-2010 04:02 AM
Motion sensor & fluorescent fixture issue trclac Electrical 5 05-10-2010 10:42 AM
4 tube fluorescent fixture with two bulbs? dyeager535 Electrical 2 02-02-2009 05:51 PM
