Fluorescent Fixture/bulbs - Electrical - DIY Chatroom Home Improvement Forum
Old 08-21-2009, 06:39 PM   #1
fluorescent fixture/bulbs
I know next to nothing about fluorescent fixtures, that being said I cant imagine them being too tough to figure out....
my problem, i got a really nice fixture, its 2' by 4' surface mount ceiling fixture, 4 bulb, with the hinged defuser door... there are 4 sets of sockets for fluorescent bulbs, im thinking great i can use this thing, all i got to do is stick in 4ea. 4' bulbs... wrong! the sockets are 45 1/8 inches apart the 4 footers are just alittle long to fit, sooooo i go to lowes ask the lighting expert do you have a bulb that fits in a 45 1/8 inch opening.. nope never heard of that before.
here is every thing i can get off the light as far as info....
williams fluorescent luminaire
HPF 04201
HE Williams
ballast = FWLSD-U 55PS
it does say on the ballast to use bulb #FT40, FT36, FQ39 for 2 bulbs
and use FQ54, FT55, FT 50, for 1 0r 2 bulbs....
when i look these bulbs up i dont get any thing that looks like they could fit in this fixture...
this fixture looks to need a thinner bulb than a regular 4 footer, and the pin sockets look to be smaller than for a regular bulb also... i know my fluorescent fixture and bulb terminalogy isnt the best....
any help would be appreciated
december45 is offline   Reply With Quote
Old 08-21-2009, 07:57 PM   #2
the Musigician
DangerMouse's Avatar
it might take two of these. i have one like it.
Old 08-21-2009, 08:11 PM   #3
the Musigician
nope, you are right on the pins...those are the small pin expensive ones.... sorry.
Cross References for Sylvania FP39/841/HO/ECO:Mfr
Product Code Product Name
OSRAM 453538 _FQ39_/841/HO
http://www.goodmart.com/products/35185.htm
DM
Old 08-21-2009, 08:36 PM   #4
Licensed electrician
Rewards Points: 1,622
Looks like you need the 4 pins on the same end of the bulb. sounds like you purchased regular T8 style bulbs with the 2 pins on each end.
Old 08-21-2009, 08:55 PM   #5
of course, its my luck to end up with a fixture that would require expensive bulbs...
the fixture does have pin sockets on each end of the fixture...probably just toss the fixture then.... cant afford $22 bulbs....
Old 08-21-2009, 09:07 PM   #6
" Euro " electrician
frenchelectrican's Avatar
The length you describing that is definty a T-5 size due the T-5's are slightly shorter than T-8 or T-12's
Not too many big box store will stock this size at the moment but they will add it one way or other and normally Electrical supply centre will have this on stock or order it real quick.
Merci,Marc
Old 08-22-2009, 12:05 PM   #7
Rewards Points: 160
Check the web for prices on these bulbs. I saw some that were fairly inexpensive. Keep one thing in mind. These low wattage bulbs last a very long time. Even though they may cost more than the fixture.
Fluorescent Lights Will Not Work g8tkeeper Electrical 5 07-30-2009 02:17 PM
Incandescent and fluorescent together Big Bill Electrical 6 11-01-2008 05:49 PM
Replacing fluorescent with recessed..thoughts darlenep Remodeling 12 08-14-2008 11:38 PM
Fluorescent fixture not working hgiljr Electrical 6 05-25-2008 11:20 AM
Recessed Fluorescent Lighting - how many bakerhouse Remodeling 2 05-13-2008 10:42 PM
