Fluorescent Bulbs - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 10:22 PM   #1
Rewards Points: 2,154
fluorescent bulbs
I know this isn't a "I hate something" site, so let me grit my teeth and say I cringed when I saw my new house has fluorescent bulbs in the kitchen. I always have trouble snapping them into place.
These are recessed into the soffit above the upper cabinets. There are three 4 ft bulbs.
I know one is burned out but I don't have time to replace it. Today the others went off by themselves. I thought, 'hmm, strange'. 15 min later, or so, they came back on. An hour later they went off again. Half an hr later they came back on. This happens again later.
Either I have a ghost or somethings wrong with the lights.
When I managed a building if a F. bulb went out and maintenance replaced it and it still didn't work it was always the ballist.
I've never seen this off then on again happen. Any info is appreciated so I'm better informed when I call an electrician.
Startingover is online now   Reply With Quote
Old 05-28-2012, 10:29 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,466
I personally love fluorescent bulbs.....I spend a lot less time changing bulbs and my electric bill is a lot less....on average, my monthly bill is about $45.
It's very unlikely that both bulbs failed or the ballasts failed on both lights. I would look for a loose connection.
One thing to try before you call in the expert....give the bulbs a twist. All too often people do not twist them properly into postion.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Startingover (05-29-2012)
Old 05-28-2012, 10:29 PM   #3
Code05's Avatar
Rewards Points: 1,104
First guess, ballast here also. Bulbs could cause this problem, but in my experience-unlikely.
You can swap it out pretty easily. How old is the ballast?
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
Old 05-28-2012, 10:33 PM   #4
Electrical Contractor
kbsparky's Avatar
Ballasts have internal thermal protection which shuts them down if they get too hot.
The symptoms you described indicates you may have an overheating ballast.
In the olde days, the ballast would just get hot enough to boil out the tar, and spew stinking smelling ooze all over the place. Now, with the thermal overload protection in place, the lights go out until the ballast cools off and then it comes on again, repeating the cycle until complete failure of the device.
Figure on replacing the ballast at least, or the entire fixture at the most.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
Old 05-28-2012, 10:33 PM   #5
Missouri Bound's Avatar
Ballasts are thermally protected...at least some are. They can cycle off and on when overheated. Your ballast is the issure here, assuming you are using the proper lamps.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Old 05-28-2012, 11:38 PM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
These lights aren't on a dimmer are they?
The Following User Says Thank You to k_buz For This Useful Post:
Old 05-29-2012, 07:47 AM   #7
thank you everyone.
Yes, this happened when I left them on all day. The house is 30 yrs old and I expect they are original ballasts.
I need an electrician for a few other things, so will make a list and wait to call him. Meanwhile I won't use these lights.
As someone pointed out isn't it strange all ballasts went out at the same time. (except they're all the same age) The house has been vacant for a year.
Old 05-29-2012, 01:01 PM   #8
Rewards Points: 156
All the ballasts may not have failed at the same time, but since the house was vacant, nobody noticed when they did fail. Yes, they can fail even when they are not being used. This is because the materials they are made with continue to break down even when they are not in use. Since they were all put back into operation at the same time, it appeared they had all failed at the same time. You must remember though, they were all installed about the same amount of time, and have received the same amount of useage, so yes, the chances of them failing at the same time is high.
av-geek is offline   Reply With Quote
The Following User Says Thank You to av-geek For This Useful Post:
Old 05-29-2012, 01:24 PM   #9
Too Short? Cut it Again!
Not sure why you don't like flourescents especially if they are hidden as in your case. You can get them in different color temperatures and with high color rendering indexes you know? I had daylight full spectrum tube up in the skylights of my home in California. Transluscent panels were flush with the ceiling. They were quite nice at night.
The 3200-3400K ones give off that greenish cast unless you get them with a better color rendering index.
Old 05-29-2012, 09:51 PM   #10
sdsester, thank you for sharing the link. Very interesting and impressive.
I don't like fluorescent bulbs because I can't get them in. They flicker for me, or at least in my last 2 homes they did. I know you put one end in and the other and give a twist, but it doesn't work for me.
From work experience I did make sure maintenance put the same colors in. Some would have a bluish cast and some yellow and it looked nicer when they were uniform.
av-geek, great explanation for my light problem. I have so much to learn about this house.
Old 05-30-2012, 06:18 AM   #11
Rewards Points: 156
If the flickering bothers you, When you get the electrician to replace your ballasts, make sure that he replaces them with electronic ballasts. They operate at a much higher frequency than the 60hz line frequency, so they don't flicker. SOME electronic ballasts though give off a high frequency ringing noise, sort of like the old tube TV's would. Some people can hear that, but most people can't. Unless you have good high frequency hearing, chances are, you won't notice it
Old 05-30-2012, 06:46 AM   #12
Rewards Points: 308
Can you buy sockets that lock the bulbs? puttster
puttster is online now   Reply With Quote
Old 05-30-2012, 07:36 AM   #13
av geek, I forgot about that but in my last house I did hear that noise from the bulbs.
The time has come for me to learn to master the art of inserting these bulbs.
Old 05-30-2012, 08:55 AM   #14
Some of the tombstones for the T8 fixtures are an enclosed type, which accept the bulb then turn 90 deg. and click in....pretty foolproof for installing the lamps properly. The T12 fixtures are usually the open ended type, but installing the lamps properly is a matter of indexing them. The lamps themselves have a little "bump" on the metal end which is the key to proper installation.
replacing fluorescent tube light with regular bulbs nikeman Electrical 7 08-07-2011 08:33 PM
Are there any power outlet adapters for 4-pin single tube fluorescent bulbs? meme111 Electrical 8 08-02-2011 10:34 PM
energy efficient Fluorescent light bulbs Samson911 Electrical 5 06-19-2011 04:47 AM
Dimmable Fluorescent Bulbs hyunelan2 Electrical 6 04-26-2011 12:10 AM
4 tube fluorescent fixture with two bulbs? dyeager535 Electrical 2 02-02-2009 05:51 PM
