Fluorescent Ballast Change Question - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2012, 05:15 PM   #1
fluorescent ballast change question
I removed the old ballast:
http://dl.dropbox.com/u/18856784/ballast-old.JPG
and replaced with a new ballast:
http://dl.dropbox.com/u/18856784/ballast-new.JPG
I put them both in, merely by connecting red to red, blue to blue, white to white, black to black.
Then I noted that the wiring scheme was different as above, and I had an extra wire.
I rewired one according to new scheme.
So now I have one wired according to new scheme, and one wired according to the old scheme.
Is it really neccessary to rewire the old one to the new scheme? Both are working.
The one that is wired to the old scheme, just has the extra wire capped off.
Both boxes run two t12 96 inch fluoresent bulbs.
herf is offline   Reply With Quote
Old 04-13-2012, 07:40 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,350
it looks like the new ballast will run two tubes !
Why dont you remove the other old ballast,
And use the new one to run both tubes.
Otherwise there will be one blue wire not used on the new ballast,
*Note the warning on the new ballast !*
The unused wire needs to be insulated to 600v .
dmxtothemax is offline   Reply With Quote
Old 04-13-2012, 09:17 PM   #3
Both new ballasts are both running two 96 inch fluorescent bulbs already.
I have replaced two old ballasts that both ran two bulbs, with two new ballasts, that each run two bulbs.
The difference is one new ballast running two bulbs is retired according to its diagram, its wires are all used.
The other new ballast was just literally "dropped" in to the original wiring scheme, red to red, blue wire to blue, white wire to white wire, black wire to black wire, leaving one blue wire left over.
The two wiring schemes are different. Yet the dropped in one, lights the lights, and appears to work fine...... Do i need to rewire it according to its diagram?
Old 04-13-2012, 10:15 PM   #4
Does the old one have a ballast that is different to the new one ?
Old 04-13-2012, 10:23 PM   #5
joed's Avatar
Rewards Points: 12,862
You need to wire the ballast according to the drawing on the ballast. Those ballasts required different wiring schemes. One even requires a special tombstone with a cutout in it.
Old 04-14-2012, 12:33 AM   #6
the old ballast is the one pictured first.
the new ballast is the one pictured second.
what is a tombstone, and what is a cutout?
I see the old one is the one that requires cutout on the diagram.
thanks for help,
herf
Old 04-14-2012, 04:37 AM   #7
Electrical Contractor
kbsparky's Avatar
Use the new wiring diagram. While the new ballast may work for a time, more likely than not it will fail prematurely if not connected correctly....
-KB
Old 04-14-2012, 07:38 AM   #8
Pure Genius
Rewards Points: 150
I knew a maintenance guy who just matched colors. He smoked 25 brand new ballasts. They did work for a day though.
Dierte is offline   Reply With Quote
Old 04-14-2012, 08:07 AM   #9
Licensed electrician
Rewards Points: 1,614
The tombstone is the end that holds the bulbs and where the electrical contacts meet the bulb.
New Fluorescent Light / NM wire ggcamp Electrical 2 04-01-2012 09:25 PM
wiring a ballast from t12 to t8 family Electrical 3 05-17-2011 08:57 AM
Home Addition's foundation question? chai3341 Building & Construction 13 01-01-2009 11:46 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
please help w/ selection of bad ballast Mack V Electrical 8 10-17-2006 09:54 AM
