Fluke Meter - Electrical - DIY Chatroom Home Improvement Forum
Old 01-03-2013, 09:17 AM   #1
jburd964's Avatar
Rewards Points: 166
Fluke Meter
What would cause odd AC voltage, 13, 24, 6, readings on Fluke meter? I have cleared it and still getting them.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 01-03-2013, 09:21 AM   #2
Rewards Points: 13,472
Going to have to share what and were your testing.
Just sounds like what's called phantom voltage.
Old 01-03-2013, 09:27 AM   #3
jburd964's Avatar
Rewards Points: 166
Sorry. 120 volt outlets. Is phantom voltage a actual voltage are nothing at all?
Old 01-03-2013, 09:50 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
Sounds like a fluke voltage (sorry couldn't resist). Probably induced phantom voltage. Connect a 60 watt light bulb across the measurement point and see if the voltage goes away.
Coastal South Carolina
Old 01-03-2013, 09:52 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,504
Are you getting 120Vac measurements at all?
If not....I bet you have a broken meter lead....
Short the leads together...if it does not go to 0 Vac (or real close), one of your leads is broken.
ddawg16 is online now   Reply With Quote
Old 01-03-2013, 10:13 AM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,928
I second the votes for phantom voltage on a dead receptacle or a broken/loose test lead. If not that, then a low battery in the meter - although Flukes don't usually have a problem with false readings on low battery.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 01-03-2013, 10:16 AM   #7
Master Electrician
Rewards Points: 3,826
Needs new battery.
brric is online now   Reply With Quote
Old 01-03-2013, 06:38 PM   #8
jburd964's Avatar
Rewards Points: 166
Thanks, I do need to change out leads, that I have and have new battery. Also will try the light bulb. Thanks
Old 01-04-2013, 12:45 AM   #9
JOATMON
ddawg16's Avatar
I go through a set of leads about once a year.....
I buy the real Fluke leads...typically off Amazon. They are made with a much softer rubber and are easier to use. The ones I like have removable tips....lets me swap in the alligator tips....sort of like having a third hand.
Also....if you have the yellow protective 'glove' for the meter, see if you can get the magnet.....they make a strap that hooks into the back of the case and it has a magnet on the end....strong enough to hold the meter when stuck to the top of a Hoffman box. Love that magnet...
The Following User Says Thank You to ddawg16 For This Useful Post:
jburd964 (01-04-2013)
Comparable meter to the Fluke 336 viper Electrical 5 02-08-2012 12:35 AM
Meter Main problem. right-sided meter? acerunner Electrical 6 07-23-2011 12:41 PM
Fluke is starting to become the meter ... hvaclover Electrical 2 11-26-2010 01:38 PM
Never buy a Fluke meter hvaclover Tools 37 03-10-2010 04:52 PM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 06:53 AM
