Flourescent Lights Flickering - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2008, 10:08 PM   #1
Rewards Points: 274
flourescent lights flickering
I installed 2 sets of 4' flourescent lights in garage. Cheapos from Lowes. It takes 3 flip of switch before they will all (4 bulbs) come on. Is the problem "cheapos from lowes?"
ugabulldog is offline   Reply With Quote
Old 08-30-2008, 11:14 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
First thing to check...are all the bulbs seated correctly?? Many times that's all it is.
If seating the bulbs doesn't fix the problem, respond with more detailed info.
New bulbs?? Hard wired or plug in? Receptacles or switch old and worn? You say it takes 3 flips...what happens on 1st & 2nd flip? etc.
Old 08-31-2008, 10:02 AM   #3
Rewards Points: 274
I wired myself, everytihng new. Plug-in receptacles, one feeding off the first. The first two flips, some bulbs come on but not all, different bulbs everytime.
Old 08-31-2008, 10:23 AM   #4
Electrician
Cheap ballasts, china crap. If you like the fixture just replace with a good ballast. but what did you expect from "Lowes"? I bought some cheapo plug in lights from HD, 7 bucks I think? I had to replace 1 ballast, but thats it, for 7 bucks they are throw aways and thats fine with me.
chris75 is offline   Reply With Quote
Old 08-31-2008, 11:40 AM   #5
Rewards Points: 82
Got a case (15) of 96" inch tubes from Lowes a few weeks ago for $30.00. Really a good price as supply wanted $50 and HD wanted $48. Sylvania.
Installed two in a brand new fixture, one bad bulb right off the bat. I am just wondering how many more are bad in this case. Since they are for my own use it will take me awhile to test them all. And you guys know how hard it is to get them back in the case once you pull them out, so testing all of them will not happen.
Old 08-31-2008, 11:41 AM   #6
Electrician
SD515's Avatar
Rewards Points: 504
Try plugging the lights into an ext cord from a different receptacle...eliminate the circuit you're having problems with. Plug one in for a couple seconds to see if it lights properly, unplug it and try the other. If they are still failing, take 'em back to Lowe's and get new ones or a different model. If they don't fail, check your connections at the recept's & switch, etc.
Old 08-31-2008, 11:49 AM   #7
Electrician
SD515's Avatar
Rewards Points: 504
I had that happen before too JV...there were 6-8 bulbs out of 30 that were junk right out of the box.
Bulldog...try swapping the bulbs around some too...my bad...
Flickering Lights nebil17 Electrical 3 08-15-2008 10:42 AM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
Flickering flourescent lights in new house Faulknertw Electrical 9 07-30-2008 09:29 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
Newbie's lights flicker and bulbs blow out MA_in_PC_Fla Electrical 11 05-21-2008 03:34 PM
