Flourescent Light Problems - Electrical - DIY Chatroom Home Improvement Forum
Old 09-15-2007, 10:28 AM   #1
flourescent light problems
Hi, I have five 4 lamp fixtures in my garage. They started burning lamps quickly, so I decided to change all the ballasts (10) total, 2 per fixture. I also installed all new lamps. Out of the 20 lamps, all but 2 fired up fine. The other 2 light up partially. Strangely, they were both on the same side of the fixture, instead of being both on the outside or both on the inside as I thought these things worked. I have basically no electrical experience, just monkey see, monkey do. I have all the reds to reds, blues to blues, yellows to yellows, blacks to blacks and whites to whites. I have also checked all the sockets and they seem to be fine. Can anybody out there help? This is driving me crazy. Thank you.
jcmmgm is offline   Reply With Quote
Old 09-15-2007, 11:03 AM   #2
Could be many reasons....cheap ballasts, cheap electronic ballasts, bad grounds
buffalonymann is offline   Reply With Quote
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Ceiling Light problems David Cleere Electrical 9 07-17-2007 06:13 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 06:22 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
