Flourescent Light Problem - RFI Noise - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2009, 04:15 PM   #1
Flourescent Light Problem - RFI noise
I installed 6 - 8' shop lights (2x2 T8's) in my work shop. They are controlled on a 4-way switch circuit. The lights work great, however when they are on they create so much RFI noise that my radio turns to complete static! Even my truck radio "sizzles out" when I pull up to the workshop when the lights are on!!!
These are cold ignition start lights from Cooper. Any ideas what is causing this problem and how I can fix it???
Thanks,
Frank
uokman is offline   Reply With Quote
Old 04-10-2009, 07:56 PM   #2
dSilanskas's Avatar
Get used to it your using a H/O bulb
dSilanskas is offline   Reply With Quote
Old 04-10-2009, 08:13 PM   #3
I have (3) sets of T-8's in my basement & I do not have any interference
I'm actually going with CFL's in recessed cans instead
Less power & I can spread the light out better
I'm going the same route with the garage
Is the radio on the same circuit?
Old 04-10-2009, 10:23 PM   #4
The bulbs are only 32w each...?
Old 04-10-2009, 10:26 PM   #5
Yes, the radio is on the same circuit at this time as I'm still using Temp power. Why would it make my truck radio get staticy when I pull up near the shop??
Old 04-10-2009, 11:47 PM   #6
Structural Engineer
What kind of ballasts are in your light fixtures? My guess is magnetic because of the radio issues. An electronic ballast will not cause this issue, or at least no to such a severe degree.
wildcat is offline   Reply With Quote
Old 04-11-2009, 09:38 AM   #7
Rewards Points: 2,350
Sounds like a shielding and grounding problem. Make sure the metal housing of the lights are grounded properly. Too many times I've seen a ground wire cut off or not connected by the installer.
Old 01-28-2010, 09:04 PM   #8
HELP!!!!! I'm about ready for a barn burning...
Well, I have checked the grounding, tried different ballasts that are "supposed" to be the most noiseless ones available - GE MAX N Ultra... and alas I still can not operate my radio without MAJOR RFI noise. Even my truck radio fuzzes out within 20 ft of the building when the flourescent lights are on!
What the heck do I try next to fix this? I am literally about ready to burn down the building...
Does anyone have suggestions?... matches and some kerosene?
Old 01-29-2010, 07:14 AM   #9
Nobody has had this problem and knows a "fix"????
GU 10 Halogen Can Light Problem cbiss Electrical 3 12-10-2008 07:52 PM
light dimmer problem DXL Electrical 5 03-30-2008 09:03 PM
Icicle at base of exterior light -- insulation problem? curls00 General DIY Discussions 1 11-20-2007 10:14 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
