Flourescent Lamp Ballast Replacement - Electrical - DIY Chatroom Home Improvement Forum
Old 10-27-2012, 07:08 PM   #1
flourescent lamp ballast replacement
I have a 2-tube, 8' flourescent ceiling fixture. Recently one of the tubes went out. Replacing the tube did not help. So I replaced the ballast. Now neither side will work. I have carefully checked the wiring visually. Both old and new ballasts were (are) for 6-8' T12 tubes.
Any advice, such as how to check the lamp with a VOM, would be appreciated.
pmstrsn is offline   Reply With Quote
Old 10-27-2012, 10:54 PM   #2
An old Tradesmen
Rewards Points: 6,548
Moved to electrical forum.
The Following User Says Thank You to beenthere For This Useful Post:
BigJim (10-27-2012)
Old 10-27-2012, 11:08 PM   #3
Missouri Bound's Avatar
You more than likely wired it wrong. For the next time this happens and one bulb goes out...switch the bulbs and see if the problem goes with the bulb. What kind of bulbs do you have? Which ballast did you use? There are a lot of combinations out there...you may have made the wrong ballast choice. Pictures may help if you can provide.
Do you want it your way or the right way?
Old 10-28-2012, 12:14 AM   #4
Rewards Points: 1,192
8' fluoresent fixtures have the end thing the the lamp need to be in right.
bobelectric is offline   Reply With Quote
Florescent Ballast Replacement Rze Electrical 12 04-29-2012 12:48 PM
Ballast for flourescent bulb chshininc Electrical 4 03-28-2012 01:54 PM
F30 Ballast Replacement DLMc Electrical 7 03-07-2012 08:17 AM
Convert 2-pin flourescent lamp socket srelf Electrical 2 10-01-2011 06:45 PM
4 Lamp 2 Ballast Fixture jhalst828 Electrical 2 06-25-2011 10:27 AM
