Flourescent Fixture Suddenly Wont Work, Wall Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2013, 02:12 PM   #1
Rewards Points: 83
flourescent fixture suddenly wont work, wall switch?
Hi
Our 4 bulb kitchen flourescent fixture wont work suddenly. I have made sure no wall switches are in the midway position. How do I check if it is the fixture or a wall switch? Could both ballasts go at the same time?
Im not sure if I replace wall switches (3way) or pull the fixture down to check the wires at the fixture?
D270 is offline   Reply With Quote
Old 10-04-2013, 03:21 PM   #2
eastcoastsparky's Avatar
Rewards Points: 150
Probably a bad ballast, there are not two ballast in there, it would be just one 4-tube ballast for the entire light
eastcoastsparky is offline   Reply With Quote
Old 10-04-2013, 04:15 PM   #3
Rewards Points: 141
Maybe someone else could weigh in on this suggestion, but I'd turn the power off at the breaker, pull out the switches and use a continuity tester to see if each switch is capable of transmitting current.
RocketGal is offline   Reply With Quote
Old 10-04-2013, 04:26 PM   #4
could be as simple as a loose wire. check the switch and the fixture terminals.
itsnotrequired is offline   Reply With Quote
Old 10-04-2013, 06:02 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,366
Use a non contact tester,
and test at switch and then light !
dmxtothemax is online now   Reply With Quote
Old 10-04-2013, 09:22 PM   #6
Resi EC
Rewards Points: 252
1 may have gone bad months ago, just went un-noticed till the second one went bad.
Check for power at the fixture, if the lamps have been replaced, it's probably the ballast
If at first you don't succeed .... do not work on live electrical
Gac66610 is offline   Reply With Quote
Old 10-04-2013, 10:02 PM   #7
Rochsolid's Avatar
Bad ballast is my bet
Rochsolid is offline   Reply With Quote
Old 10-05-2013, 05:47 AM   #8
Rewards Points: 1,216
Check the lamps first.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
PoleCat (10-05-2013)
Old 10-05-2013, 06:56 AM   #9
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by eastcoastsparky View Post
There are not two ballast in there, it would be just one 4-tube ballast for the entire light
Not always entirely true...
The Following User Says Thank You to stickboy1375 For This Useful Post:
darren (10-05-2013)
Old 10-05-2013, 07:13 AM   #10
Rewards Points: 476
Originally Posted by D270 View Post
Hi
i guess you like twisted th bulb's back and forth in the holder ?? sometime's my 2 bulb unit will need that, most likely the ballest smell the ballest or look and see if black crap has bubbled out , like ran down real bad, if it smell like something bunt that it is bad. if this just happen than i would belive balest, if you have a volt meter check for voltage , if you aren't savey with this don't do it. get some one that know's .
del schisler is offline   Reply With Quote
Old 10-05-2013, 07:59 AM   #11
Rewards Points: 150
usually most new ones are
Old 10-05-2013, 12:27 PM   #12
E2 Electrician
It all depends on the manufacture.... just saying anyway.
Old 10-08-2013, 07:24 PM   #13
Rewards Points: 83
Wow thanks for all the responses. It is about 7 years old, T12, 40w bulbs x4.
I looked... 2 ballasts. One light had been intermittently going off and on every once and a while. Now the light will turn on, then sometimes the light will shut itself off. Flicking the 3way switch won't help, nor will trying the other switch once it goes off on its own.
Then if someone tries the light again in an hour or so... Sometimes it goes on sometimes not. Replacement ballasts are $25 each, and a similar T8 fixture is $100.
I will replace all 4 bulbs, try new switches then it only makes sense to replace the fixture versus changing out the ballasts above my head on a ladder... Thoughts?
Old 10-08-2013, 08:00 PM   #14
Rewards Points: 1,192
Remember, they quit making t-12 lamps. Go from there.
bobelectric is offline   Reply With Quote
Old 10-09-2013, 01:10 PM   #15
Rewards Points: 79
Ballast. I had the same problem with my light in the laundry room. You'd flick the switch, the light would flick on and off (with the switch still on). If you left the switch on it would come on eventually. It worked fine once it was warmed up. I thought it was the switch at first (slow) but it ended up being the ballast. You can get a decent 4 lamp T8 for less than $100.
CheapCharlie is offline   Reply With Quote
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 11:43 AM
3 way wiring- Switch, fixture , fixture, switch Warrenpfjr Electrical 7 03-30-2011 07:51 PM
I'm having trouble replacing a wall switch jamesjames Electrical 6 03-14-2010 01:44 AM
installed recessed lights but now switch does not work auggie77 Electrical 2 08-02-2009 10:11 AM
find switch to control outdoor light fixture CaymanAg Electrical 1 07-10-2005 08:43 PM
