Flouresant Lights - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 01:07 PM   #1
flouresant lights
I have 4ft flouresent lights in both bathrooms I had to change everything
in the one bath my question is why do I have to change everything transfomer and bulbs.I should not have to change the transformer every time or do I? Thanks in advance for the help!!
joseph44 is offline   Reply With Quote
Old 12-02-2008, 03:25 PM   #2
Rewards Points: 820
No, you should not have to change the transformer (ballast) every time you change bulbs. Could it be possible though, that the wrong bulbs were installed, thus causing the transformer to burn out?
Make sure the bulb wattage is not higher than what the transformer is rated for.
Ultrarunner2017 is offline   Reply With Quote
Old 12-03-2008, 01:08 PM   #3
flouresent lights
Thanks KE2KB never dawned on me to look at that I WILL FROM NOW ON! You have a great wk/nd!!
Old 12-03-2008, 04:53 PM   #4
Idiot Emeritus
Rewards Points: 1,492
Make sure the lamps are the right type too.
If the ballast is designed for T12 lamps and T8's are installed, it'll burn up the ballast in a couple of hours.
You'll need to look on the ballast label and make sure the lamp type and wattage are listed.
Rob
micromind is offline   Reply With Quote
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
Adding can lights to an existing circuit TexasEd Electrical 1 06-17-2008 08:23 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 10:55 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
