Old 02-11-2013, 04:29 PM   #1
Florsent lights
How do I connect 3 florsent lights together
Robersher is offline   Reply With Quote
Old 02-11-2013, 04:33 PM   #2
Florsent lights
what is a florsent light?
hammerlane is offline   Reply With Quote
Old 02-11-2013, 04:35 PM   #3
Florsent lights
http://www.bing.com/images/search?q=...electedIndex=0
Old 02-11-2013, 04:54 PM   #4
Florsent lights
Hammerlane..that would be fluorescent lights......geeeez thought you would figure that one out. Did you know that you can take all the vowels out of a sentence nd hrdly tll th dffrnc?
techpappy is offline   Reply With Quote
Old 02-11-2013, 04:55 PM   #5
Florsent lights
I have a food pantry that I would like to install 3 fluorescent light fixtures in,
one 36" on the top and one 60" on each side. How do I go about connecting all of them together? Thanks for for your help.
Old 02-11-2013, 04:58 PM   #6
Florsent lights
I sure knew that. lol
I spell farm, EIEIO. Good enough for old McDonald, good enough for me.
Old 02-11-2013, 05:09 PM   #7
MarginallyQualified
Florsent lights
I would like to install 3 fluorescent light fixtures...
How pretty does it need to be?
Do you have access (attic?) above the ceiling?
Are you willing to punch & patch holes in the ceiling?
Can you bend conduit?
Old 02-11-2013, 05:15 PM   #8
Florsent lights
find a diagram that is similar to what you want to do..assuming you want one switch to control all 3 lites
*****ground wires not shown for ease of drawing******
Lets see if the code police nail diagrams 2,3 and 4 for no neutral at the switch location
Florsent lights-3-lites-daisy-chained.jpg   Florsent lights-4-lites-power-1st-lite-switch-other-end.jpg   Florsent lights-control-multiple-lites.jpg   Florsent lights-fans-switch-j-box.jpg   Florsent lights-634y6983y476.jpg
Old 02-12-2013, 07:43 AM   #9
Florsent lights
Thanks for your drawings, the three fixtures I would like to install are going inside a food pantry. I have one 36" going across the top and two 60" going down each side. There are two light switches on the outside and I was going to replace one of these with a duel switch.
Old 02-12-2013, 07:49 AM   #10
Florsent lights
SO you want one switch for each lite?
Old 02-12-2013, 08:21 AM   #11
Florsent lights
No I would like to tie all three together.
Old 02-12-2013, 08:29 AM   #12
Florsent lights
So the 2 switches currently outside control other devices?
And you want to replace one of the single switches with a double switch having one of the double switches control all the pantry lights??
Old 02-12-2013, 08:41 AM   #13
Master Electrician
Florsent lights
Screws? Bolts? Gorilla Glue?
Really?
Mark
Licensed Master Electrician
Commonwealth of Virginia
busman is offline   Reply With Quote
Old 02-12-2013, 08:50 AM   #14
Florsent lights
That is correct.
Old 02-12-2013, 08:53 AM   #15
MarginallyQualified
Florsent lights
That is correct.
What is correct?
Do you have attic access above the ceiling?
How *specifically* do you envision this to look when all is done?
Trouble with GFCI Outlet + Switch for pool lights kentf Electrical 5 05-23-2011 12:37 PM
Problem: Puck lights w/ touch-sensitive switch mapsedge Electrical 1 03-14-2011 08:20 AM
Low Voltage Exterior Stair Lights Jupe Blue Electrical 2 02-16-2011 07:28 AM
undercabinet puck lights ccalmonte Electrical 7 08-05-2008 09:25 PM
Added can lights, tripping GFI tandyt Electrical 3 05-18-2008 10:55 AM
