Florescent Lights On A Dimmer Swtich - Electrical - DIY Chatroom Home Improvement Forum
Old 08-15-2009, 10:41 AM   #1
Florescent lights on a dimmer swtich
I put a new circuline florescent light in the spare bedrooms in my house. They work great but my wife said she didn't like how bright they were so I bought a dimmer switch and installed it.
With the dimmer switch installed the light flickers a lot and the dimmer function doesn't even work. As well a high pitch squeal comes from the switch.
Now that I think about it I've never installed a dimmer switch on a florescent light ever so my question is can you put a florescent light on a dimmer? or is that not possible. Do I need a special bulb or switch or am I just SOL?
McCool is offline   Reply With Quote
Old 08-15-2009, 11:06 AM   #2
Licensed electrician
Rewards Points: 1,610
You can use dimmers with fluorescent lights providing that either or both the ballast and bulb are dimmable. I would doubt that this is the case with your circleline bulbs.
Old 08-15-2009, 11:12 AM   #3
Rewards Points: 160
It will be much easier to change the fixture to incandescent. Florescent dimmers are more expensive than fixtures. Or live with the fixture you have minus the dimmer.
Old 08-15-2009, 01:07 PM   #4
" Euro " electrician
frenchelectrican's Avatar
If your ballast on the luminaire did not say about dimmer useage then you can not use the dimmer at all it will really affect the performace.
But if this is a screw in bulb or whole luminaire which you got from big box and there are few that do stated can use with dimmer however that one item you have to watch out with it.
Merci,Marc
Wiring a dimmer to 2 lights bannin Electrical 3 08-04-2009 01:37 PM
How many 50 pot lights can I attach to a single dimmer? atm Electrical 1 04-16-2009 10:10 PM
Dimmer Switch On other lights off. TonytheTiger12300 Electrical 5 12-23-2008 09:47 AM
Replacing Dimmer for kitchen lights tmcguirk Electrical 2 04-16-2008 08:38 PM
Dimmer on LED Lights Greg in PHX Electrical 3 03-17-2008 07:00 PM
