Florescent Light Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 03-10-2011, 06:33 PM   #1
Solutions (handyman)
Rewards Points: 362
Florescent Light issue
Our community hall has several long (about 8') double florescent lights. Some are working and some aren't. In one, one of the bulbs works but the second side does not. They are fairly old, ... as in over a decade or two, so replacement parts may be a problem. What could cause the problem? Ballasts, old bulbs wiring? And, what would be recommended.
Mark Harvey is offline   Reply With Quote
Old 03-10-2011, 07:30 PM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Typically replacement parts should be fairly easy to get. If the ballast are really old, you'll most likely be looking at needing ballasts for the most part (and a good idea to change the bulbs too, unless you know they are new), and maybe some lampholders if some are broken, but try new bulbs first if you have a couple extra. Swap out both at the same time...it should give you an idea if it's just the bulbs or the ballast.
You might consider replacing your current fixtures with new T8 fixtures. They're more efficient.
Kyle
The Following User Says Thank You to SD515 For This Useful Post:
Mark Harvey (03-10-2011)
Old 03-11-2011, 01:40 AM   #3
Electrical Supplier
Rewards Points: 150
Start with flipping the bulbs around, by this I mean keep them on the same side, but switch the ends to the other end. (Rotate 180 degrees on the same side)
If this doesnt work, get new bulbs and if those dont illuminate, rotate as above......
If that still doesnt work, get a new ballast or consider T8 fixture
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
The Following User Says Thank You to LyonsElecSupply For This Useful Post:
Mark Harvey (03-11-2011)
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
Motion Activated Light Control Issue mbaudler Electrical 9 12-14-2010 09:52 AM
Condensation in overhead light JB Toyz Electrical 0 12-06-2009 03:40 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
