floor recepetacles
How do I put floor receptacles in an above grade concrete floor? The floor will be poured to 3" and then +/- ,1/16" will be ground off. There is a basement underneath. The subfloor is 3/4" plywood. Hoping to install just a couple of the ones you see with a flat brass screw type cap. Specifics as to receptacle to use and how to install ...would be much appreciated. We are two weeks out to the pour and blew it by waiting until the last minute to figure this out. Save my bacon! lee
I hope this helps. You'll have to get them at an electrical supply house. Not you Home Depot. Here is a link to the product I think you want: covers are seperate
http://www.hubbellcatalog.com/raco/R...&FAM=RacoBoxes |
Do a web search, or go right to a supply house and ask to see some Lew boxes. They are typically the ones you see with the brass screw caps.
I apologize, the link I sent doesn't work. Try this one instead: Hope it's not too late!
http://www.hubbellcatalog.com/hubbel...FAM=DSystemOne |
| All times are GMT -4. The time now is 02:47 AM. |
