Floor Lamp Doesn't Work In Some Outlets - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-06-2010, 09:48 AM   #31
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Originally Posted by AllanJ View Post
Here is one thing I sometimes do (including what I did to find out that a power plug was bad). Take a needle or pin and poke the cord )
I understand what you are doing AllanJ but personally I would much rather suggest the lamp be disassembled enough to be able to test the conductors at the switch.
Ok, how about just to determine the facts:
lamp only works in GFCI recep
this lamp does not work in a non-gfci protected recep (any portion of the lamp either the touch spot or the actual switched section)
other lamps work in the receps this lamp doesn't work in
nothing is tripping (either GFCI or breaker) when trying this lamp
you have actually checked the receptacles with a one of those plug in testers that check for polarity and ground connections, yes?
question: do you have to use the touch point switch for either section of the lamp to work or are the two sections totally separate? Does the manual switch have to be on for either section to work or are they totally separate?
Do you have an ohmmeter or a continuity tester? If so, attempt to test from each of the plug points (hot, neutral, ground) to the lamp housing and the touch pad.
Old 04-06-2010, 09:23 PM   #32
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by jlmran View Post
How old is the lamp?
(No further replies allowed from those who have identified themselves as couch potatoes! )
MDR !!! { LOL } very funny but I have a feeling that is a electronic controlled luminaire that need ground for referince point.
Senice the OP did mention one part is halogen but what about other parts ??
Merci,Marc
Old 04-06-2010, 09:35 PM   #33
nap
You talking to me?
nap's Avatar
that's what I was shooting for with my post as well.
Old 04-06-2010, 09:42 PM   #34
Nap.,
I think this part may be a shot in dark but possiblty that the luminarie did have both netural and ground crossed or tied together in the controller ?
{ I am not suprised with chinese stuff whatever ya got I get it in France so it is no stranger with that kind of stuff }
Merci,Marc
Old 04-06-2010, 10:40 PM   #35
Rewards Points: 506
As was I...thus the age question.
jlmran is offline   Reply With Quote
Old 04-09-2010, 11:17 AM   #36
Rewards Points: 1,192
Originally Posted by jp45 View Post
The house is less than 3 years old, and all the plugs test ok for ground.
Thanks for the info.
He said all receptacles have a proven ground.
bobelectric is offline   Reply With Quote
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 07:23 PM
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 07:07 PM
Code issues for witch operated outlets above kitchen cabinets? jcims Electrical 5 03-25-2009 07:28 PM
tub faucet won't work newatthis Plumbing 4 10-31-2008 01:57 PM
Outlets Work - Switches Do Not? Quick Electrical 6 08-13-2008 04:10 PM
