Floor Lamp Doesn't Work In Some Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 04-04-2010, 06:40 PM   #1
Woodworker
Unhappy
Floor lamp doesn't work in some outlets
I have tested the outlets and they work for other lamps, but the floor lamp only works on the GFCI outlets in the house. The floor lamp will not work in any of the non GFC! outlets in the house. The floor lamp has a 3 prong cord. It has 2 lights. The one on the top is contorlled by touching a spot just above the switch that controls the other light which is a halogen reading light.
jp45 is offline   Reply With Quote
Old 04-04-2010, 06:44 PM   #2
Rewards Points: 1,192
I'll watch this one from the couch.
bobelectric is offline   Reply With Quote
Old 04-04-2010, 06:54 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Eh? that is instering on and do this luminaire do have two wire cord or three wire cord ??
And this floor luminare is flourscent or halgon or what it have plus it have dimmer in there ?
Excuze moi, Bob., can you pass the popcorn to moi ??
I am hungry for a popcorn at the moment.
Merci,Marc
Old 04-04-2010, 07:04 PM   #4
Master Electrician
Rewards Points: 3,964
Maybe the floor lamp thinks it needs a floor receptacle.
brric is offline   Reply With Quote
Old 04-04-2010, 07:22 PM   #5
Learning by Doing
Leah Frances's Avatar
Maybe it's bi-polar.....Wait, that's not funny....
Is that funny?
How about some more information....
- Will it work plugged into an extension cord?
- Is it damaged, old, antique, rewired?
I've never seen a lamp with a 3-prong plug....
We need more information to help you... till then, I'm joining the boys on the couch. Extra salt on my popcorn please.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-04-2010, 07:27 PM   #6
Leah.,
I have see couple lampés that have 3 wire cords on it both North Americiané and European verison it little more common to find that in European side.
Merci,Marc
Old 04-04-2010, 07:35 PM   #7
Learning by Doing
No big surprise, I've yet to 'see it all...'
BTW I'm taking my couch time on the front porch - 77 degrees F light breeze bringing all the amazing scents of spring, tulips waving. Dogs milling about with the chickens, and a better Sunday could not be had.
Old 04-04-2010, 07:52 PM   #8
Rewards Points: 1,548
Bad power cord plug? Try jiggling the cord where it goes into the plug and also jiggling the plug in the outlet.
Maybe it is only coincidental that it was not working in the non-GFCI outlets.
Once my father bought six floor lamps because they were on sale but we only needed two, the other four were stored in the basement for several years. Then we got them out and two did not work. Too late to return them to the store. Turned out that the power plug was bad, they had some kind of automated manufacturing process that stripped the insulation off the lamp cord, bent the wires into position, and pressed the bare wire ends against the prongs while molding the plug from liquid plastic. No springs or clamps or solder. On some the insulation didn't get stripped off properly during that process.
Old 04-05-2010, 07:01 AM   #9
Electrician
SD515's Avatar
Rewards Points: 504
Is that funny?
I thought that was pretty funny
Kyle
Old 04-05-2010, 10:28 AM   #10
Woodworker
The floor lamp does have a 3 prong cord. It has 2 lights. The light on the top is controlled by touching a button above the switch that controls the reading light below. The reading light is a halogen.
Old 04-05-2010, 10:30 AM   #11
Woodworker
The floor lamp has not been rewired. It is about 9 years old. It was a very expensive lamp, or I would just go buy a new one.
Old 04-05-2010, 10:51 AM   #12
Master Electrician
if it's got a three prong plug then your most likely problem is that your house is old and there's no grounds run to the plugs. The gfci kind of circumvents the no ground problem that some devices(i've recently found out) need to have. The only answer to this on if that's what the problem is, is to either run new wire all over you house with a ground . Or install a GFCI plug in the place where you want to plug in the light. Be sure to mark the plug with the "no ground" sticker.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
secutanudu (04-05-2010)
Old 04-05-2010, 11:23 AM   #13
Woodworker
The house is less than 3 years old, and all the plugs test ok for ground.
Thanks for the info.
Old 04-05-2010, 11:59 AM   #14
Master Electrician
is there room on that couch?
Old 04-05-2010, 12:01 PM   #15
Learning by Doing
There is always room for the electrical boys (and gals).
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 07:23 PM
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 07:07 PM
Code issues for witch operated outlets above kitchen cabinets? jcims Electrical 5 03-25-2009 07:28 PM
tub faucet won't work newatthis Plumbing 4 10-31-2008 01:57 PM
Outlets Work - Switches Do Not? Quick Electrical 6 08-13-2008 04:10 PM
