Old 09-29-2006, 06:05 AM   #1
Floor Box Installation
I plan to install a floor box in concrete which will provide an outlet in the middle of a living room floor. The instructions that came with the PVC floor box are unclear. Is the floor box and the conduit that is attached to it just laid on ground level and secured with rebar? The box itself doesn't seem deep enough to be buried any at all. I have had experience burying conduit under concrete, but have never installed a floor box.
TimothyGa is offline   Reply With Quote
Old 09-29-2006, 04:53 PM   #2
the box needs to be set to be either flush with the finish floor or just a little bit under the finish floor. maybe 1/8 inch.
Secure any way you can.
If you run conduit to the floor box the nec depth is Zero inches. The concrete people may want more to keep the concret from cracking.
Secure any way you can, or be there when they pour to keep the box in the place you want.
jwhite is offline   Reply With Quote
Alside Sliding Door Installation sandyman720 Building & Construction 5 08-27-2007 01:50 PM
Sump pump installation moggi1964 Plumbing 9 04-25-2007 09:28 PM
Window Well Installation Bill46 General Discussion 1 04-03-2007 05:49 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
