Flood/Spot Light Lamps? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2013, 09:33 AM   #1
Rewards Points: 77
Hello Gurus,
So I'm replacing some 30 year old flood light boxes on my house since they are starting to rust out and all the rubber/foam gaskets dried out and broken. I purchased these: http://www.homedepot.com/p/Red-Dot-L...G#.UmE1753D9aQ
My question is are these only rated for PAR38 Halogen(incandescent) lights up to 150W? I can't use a CFL or LED w/transformer correct?
Thanks,
~S
Skelleyman is offline   Reply With Quote
Old 10-18-2013, 09:49 AM   #2
PoleCat's Avatar
Rewards Points: 1,646
You can put any bulb with a mogul base in there up to the listed wattage. The traditional Par 38 bulbs mate with the gasket better.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-18-2013, 09:22 PM   #3
dmxtothemax's Avatar
Rewards Points: 5,106
Originally Posted by Skelleyman View Post
Hello Gurus,
Thanks,
~S
Are you aware that those lights are not rated or listed ?
But something simuliar you can use a CFL style par 38 lamp,
It will seal ok, as that fitting is made for par 38 style lamps.
dmxtothemax is offline   Reply With Quote
Old 10-19-2013, 06:57 AM   #4
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
I have this type of LED bulb in a couple of my floods works like a charm .....!!
http://www.homedepot.com/p/Unbranded...9#.UmJjkYU4m1A
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 10-21-2013, 09:58 PM   #5
Rewards Points: 121
Wow, is that what you guys would typically pay for a bulb like that? I bought some similar LED bulbs this summer for about $15 each.
readar is offline   Reply With Quote
Old 10-21-2013, 10:16 PM   #6
Rewards Points: 45
Looks like a 4-pack...so, around $17/ea.
RunningSparky is offline   Reply With Quote
The Following User Says Thank You to RunningSparky For This Useful Post:
Philly Master (10-22-2013)
Old 10-21-2013, 10:25 PM   #7
Rewards Points: 121
Oh, missed that, thanks. I thought I found one thing we had cheaper up here than you guys...
Old 10-22-2013, 01:48 PM   #8
Rewards Points: 77
Keep out the water?
Excellent. Thanks How do well they hold up to the weather, rain, snow sleet, etc?
Thanks,
~S
Old 10-22-2013, 02:55 PM   #9
Oso954's Avatar
Rewards Points: 768
Mogul base ?
Perhaps you meant medium.
Oso954 is offline   Reply With Quote
Old 10-22-2013, 06:02 PM   #10
I thought that was odd too !
There E28 base, or standard edison screw,
Were as mogul is E38 or E40.
Old 10-23-2013, 05:22 AM   #11
Rewards Points: 516
Thanks,
~S
fine ...LOL ... they are sealed pic one up and look at it ....
Old 10-23-2013, 06:19 AM   #12
PoleCat's Avatar
Originally Posted by Oso954 View Post
Mogul base ?
You say tomato, I say rutabaga. The mogul is for the over sized screw in bulbs isn't it. Or is it any size other than standard? Over the years I have noticed my vocabulary hasn't become smaller but my memory of what all them fancy words mean has deteriorated.
Old 10-23-2013, 05:42 PM   #13
That's all right ! we all get forgetful sometimes !
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 10:37 PM
dimmer 'crossfade' when combining light circuits mitchl Electrical 8 12-11-2011 04:00 PM
2 Wires in to light, 3 Wires out, no juice on the switch prytoo Electrical 4 11-28-2011 06:24 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
