Float Switch With Contactor And Pump - Electrical - DIY Chatroom Home Improvement Forum
Old 04-10-2010, 01:53 PM   #1
contactor with coil and aux contacts
Hi,
i want to run 3 phase pump with contactor.
The contactor have A1,A2 coil(220 volts), L1,L2,L3 and T1,T2,T3 with NO NC
i want to run the pump automatic when the water level in the tank reaches half, as i know i required cable type float level
My question is,
1. if i supply Line to A1 and netural to A2(220volts) then coil will energise and pump will start continously, but how to use NO and NC to control the contactor?, with rotatry switch(on/off).
Can anyone explain with schematic.
ismat143 is offline   Reply With Quote
Old 04-10-2010, 02:10 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
nevermind, I see in the title you say they are aux contacts. With the system you have I see no need to use the aux contacts for anything.
Old 04-10-2010, 02:13 PM   #3
Idiot Emeritus
Rewards Points: 1,492
The NO and NC are used only with momentary devices, like start/stop buttons. If the float is a maintained contact, just wire it in series with the coil.
NO and NC are not used with maintained contacts.
If there are two floats (one to start the pump, the other to stop it), then the NO and NC are needed.
Rob
micromind is offline   Reply With Quote
Old 04-10-2010, 02:14 PM   #4
Model no. LC1D32 TeSys
Old 04-10-2010, 02:23 PM   #5
Idiot Emeritus
I recently installed a bunch of similar contactors in a process controller. They were Telemecanique (just like yours), but LC1D09s. A bit smaller.
They can be mounted to a flat surface with screws, or they'll clip on to a DIN rail.
Rob
Old 04-10-2010, 03:11 PM   #6
You wrote,
my question,
if two floats then how to use NO and NC, please explain
Old 04-10-2010, 03:33 PM   #7
An old Tradesmen
Rewards Points: 6,112
Ismat143:
Please don't use the round red button with the explanation point in it, to respond to a post.
That is the report post button. It sends an email to all mods, and the Admin. And is used to tell use an improper post has been made.
Old 04-10-2010, 04:24 PM   #8
Float switch with contactor and pump
Hi,
According to attached schematic, If i connect Float and pump with contactor is it correct?
Old 04-10-2010, 05:12 PM   #9
Try again...
Only looked at the left one--
If you are asking if it would work, I would say it could work, as long as the float leads are brown = common, black = N.O. (normally open when hanging), and blue = N.C. (normally closed when hanging) BUT your pump motor is three-phase, and you typically don't use the full line voltage to control the motor.
Keep in mind the following for the left one:
Upper float turns the pump ON when it floats
Lower float turns the pump OFF when it drops
The N.O. contacts on the contactor are open when the coil is not energized (pump is off), and closed when the coil is energized (pump is on).
Proper:
A1 and A2 are your control voltage, and must be kept separate from L1, L2, and L3. Therefore, say, for 120VAC control voltage (because you have a terminal called N, or neutral) your voltage comes in through A1, has to go through the lower float, then a set of wires through the upper float to the coil (other side of coil connected to N). Then you need a parallel set of wires that leaves the lower float and goes through the contactor's N.O. contacts and goes to the coil to hold in the contactor as the upper float drops out. The contactor will drop out when the lower float drops.
Note: You can switch the order of the devices if you want, meaning A1 goes to the upper float first with the contactor's N.O. contacts wired in parallel, then both join up and go to the lower float, then to the coil.
Draw it again and we'll see how you do...notice I didn't tell you which float contacts to use. If you know the actual functions of the float connections, please post them along with any other info about this.
Willis
williswires is offline   Reply With Quote
Old 04-10-2010, 05:30 PM   #10
...just found your other thread...
It's best to keep the original thread going for all related questions instead of creating a new one. That way all the info is in the same place.
If this is directly related to your other thread, please ask the MODS to move it over there...
Willis
Old 04-10-2010, 05:34 PM   #11
Rewards Points: 58
Originally Posted by ismat143 View Post
You wrote,
my question,
The float switch connected in series with the contactor coil will fill on low (close contactor) and stop (open contactor) on full without using anything but the float switch and the contactor coil.
Old 04-10-2010, 05:36 PM   #12
I don't know which thread to respond to - another one was started with a schematic.
Please identify ALL info for your question
what is the purpose of your pump? is it to empty a tank once it gets full? is it to fill a tank back up once it gets low? is it to maintain a constant level in the tank?
  • how many floats will you have?
  • what do you want your rotary switch to do? (auto/off/manual or something else?)
  • what voltage is your pump?
  • is your control voltage 220V as you mentioned?
  • where will your control voltage come from?
  • what are the color codes of your float wires?how many floats will you have?
Willis
Old 04-11-2010, 06:16 AM   #13
Answers for the questions,
1.what is the purpose of your pump?
ans. Its pumping water from well(submersible pump),it is to fill a tank back up once it gets low.
2.how many floats will you have?
ans. i have only one float(with three wires brown,black and blue)
3.what do you want your rotary switch to do?
ans.its purpose is to (auto/off/manual).
4.what voltage is your pump?
ans. 380 to 420 volts(3 phase)
5. is your control voltage 220V as you mentioned?
ans. yes it is 220 to 230 volts
6.where will your control voltage come from?
ans. from supply line(L) and Netural(N)
Old 04-11-2010, 06:42 AM   #14
An old Tradesmen
You should list what country your in.
In most/many countries, 220 doesn't use a neutral. Are you calling 277, 220? 277 does use a neutral.
Sounds like your using 50hz.
Both of your drawings are incorrect, and would have the pump running continuous.
Old 04-11-2010, 11:36 AM   #15
Rewards Points: 1,418
It will not work properly unless the float(s) operate one float switch using a loose linkage.
1. As the water level drops, the pump should be off.
2. When the water level gets low enough, the pump turns on.
3. As the water level rises, the pump stays on.
4. When the water level gets high enough, the pump turns off.
Two (separate) pump switches each with its own float tightly linked, and NO/NC switches on the contactor unit, are unable to fulfill both conditions 2 and 4 with a fairly large distance between the turn on and turn off levels.
For a 220 volt coil and 220 volts from phase to phase, you can get the control (coil) current from any two of the 3-phase legs.
Example: Phase leg to float switch to coil A1 then coil A2 to another phase leg. Choose the float switch terminals (two of the three wires black, blue, brown) that close when the float drops far enough and that open when the float rises far enough.
