Old 01-22-2013, 07:36 PM   #1
Flir image of panel - is this a hazard
Hi all..I have a thermal image of my electrical panel. As you can see a few of my breakers are "warm". The two at the top are GFI breakers for the kitchen. The upper right breaker tends to trip every so often..would this be due to a bad breaker?connection?
Also, you can see the electric water heater breaker (mid right side) which is also "warm", as well as the wire (which you can see coming out of the top of panel). Now none of these are warm at all to the touch, but it seems to me that I have some issues.
Any suggestions?
Thanks!
markley is offline   Reply With Quote
Old 01-22-2013, 07:40 PM   #2
I would take the cover off and check the amperage of the wires coming off of those breakers.
Most likely they are just fine if they are not hot to the touch.
Bluehawks is offline   Reply With Quote
Old 01-22-2013, 08:47 PM   #3
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Whatever breaker that is I would turn it off and check that circuit out. Or have a qualified electrician check it out for you. If you have an amp meter it would be nice to check how much that circuit is drawing.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-22-2013, 08:50 PM   #4
Are you referring to the brightest breaker? That is the water heater breaker.
Old 01-22-2013, 08:52 PM   #5
rrolleston's Avatar
Yeah that thing is off the charts as far as the scale on the right.
Old 01-22-2013, 08:53 PM   #6
Missouri Bound's Avatar
What number concern you? 17 deg C is only 62 deg F...that certainly is NOT warm.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
Speedy Petey (01-22-2013)
Old 01-22-2013, 09:00 PM   #7
Yeah..as i said none of the circuits are warm at all to the touch.
Old 01-22-2013, 09:07 PM   #8
Licensed Electrical Cont.
Speedy Petey's Avatar
What Missouri said. If the user has the thing on a 17.4C scale then that image is VERY misleading.
Old 01-22-2013, 09:14 PM   #9
Yes..the scale is 17.4 degrees C. The only thing that is alarming to me is how they stand out.
Old 01-22-2013, 09:17 PM   #10
rrolleston's Avatar
My bad now I notice what range the scale was set at. That is not too bad. I know our tankless water heater breakers get warm too.
Old 01-22-2013, 09:17 PM   #11
Things are not always what they seem.
Old 01-22-2013, 09:18 PM   #12
Thanks for all the replies!!
Old 01-22-2013, 09:20 PM   #13
rrolleston's Avatar
What is the temp of the room that the breaker panel is in?
Old 01-22-2013, 09:25 PM   #14
It was relatively cool.. 50's?
Old 01-22-2013, 09:26 PM   #15
bbo
I'd guess he is ~ 50F
bbo is offline   Reply With Quote
Sub panel to sub panel feeding tvfd27 Electrical 1 08-21-2012 04:01 PM
Section 310.15(B)(6) vs. 210.4. Don't assume, call your friendly AHJs! Daneel Electrical 3 04-11-2012 08:24 AM
Garage Sub Panel Questions mscanlon01 Electrical 3 07-20-2011 11:03 AM
Panel cleanup gdoucette Electrical 5 06-26-2010 03:01 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 11:37 AM
