-   -   Flip light switches? (http://www.diychatroom.com/f18/flip-light-switches-51804/)
techprincesse 08-27-2009 04:03 PM
Hi all,
I wanted to know if its possible to just rotate a lightswitch so the light flips UP for on and DOWN for off? I bought a house and seems like half of the light switches are upside down? I removed the switch plate and it seems I can just unscrew and rotate it and then re-screw, but I wanted to get a second opinion.
Even the dimmers dim UP for off and down for bright! Thanks in advance for your help! =)
darren 08-27-2009 04:16 PM
Yup you sure can, i had a few in my house like that and was wondering what the person was thinking when they installed them.
Make sure you turn the breaker off before doing this, no need to get a shock for no reason.
Jim Hart 08-27-2009 04:24 PM
Make sure that they aren't threeway switches (two switches controlling one light). They will end up "backwards" again if they are.
EBFD6 08-27-2009 04:28 PM
Are you sure these aren't 3-ways? If they really are single poles then they should say "ON" and "OFF" right on the switch.
If the switch reads "NO" instead of "ON" then obviously it is installed incorrectly and should be turned :laughing: .
As was stated previously, turn off the power and turn the switch right side up.
Wildie 08-27-2009 08:13 PM
None of the switches in my house have ON on them!
The toggle has a little bump exposed when in the ON position!
Red Squirrel 08-27-2009 09:03 PM
I find it funny how some people install switches and receptacles upside down. Most of my receptacles in my house were upside down. But yeah it's safe to switch it.
EBFD6 08-28-2009 02:13 PM
There is no such thing as upside down when it comes to receptacles. It is all a matter of personal preference. I typically install receptacles ground down in residential and ground up in commercial/industrial. This is something that gets debated all of the time amongst electricians. Everyone has reasons why their way is the right way and the other way is wrong, but there is no code or manufacturer recommendation that guides this, as I said before, just personal preference.
edit to add : I just noticed Red Squirrel is from Canada and I have no idea about the Canadian Electrical Code so I may be wrong in correcting him, it could be a Canadian thing. However, in the US, my statement holds true.
spark plug 08-28-2009 02:24 PM
Switch "switching" Upside down!
A good way (for beginning DIY'rs) to identify a Three way Or Four way Switch is to see if it has ON/OFF markings. If it doesn't. It's a Three way switch!!! (No matter what):yes::no::drink:Don't Drink and Drive!!!
Willie T 08-28-2009 02:35 PM
This is the story as I've always understood it.
From another source:
"Years ago ,the code did require the ground port be on top in medical facilities only.
The reasoning was in the event a metal object were to fall onto a plug that was not inserted completely, the metal object would hit the ground prong first, and not cause any sparks. I believe this was due to the highly flammable anesthesia that was used back then.
Since large union contractors typically did the hospital work, this practice of the ground on top filtered out into other jobs, and is still done by many contractors as a standard.
Otherwise , there is no specific requirement by any code."
True or not, I cannot say.
Red Squirrel 08-28-2009 03:02 PM
That is interesting. I work at a hospital and most of the plugs ARE upsidedown. It's a fairly new building too (1990).
techprincesse 08-28-2009 03:29 PM
Thanks for the responses all! I dont have my internet at the new house yet so I have to wait til work to reply. All of mine say ON and OFF except the 2 dimmers which say nothing. One is a rotary dimmer and the other is a sliding dimmer.
Now I have 2-3 switches that are missing switchplate covers and I cannot find the proper cover for them. Are there any online sources to find hard to find switchplate covers? I have 2 that is large rectangle on one side and then what looks like 2 circular outlets on the next. I tried Home Depot, Lowes and even Walmart and cannot find this type for the life of me...
Thurman 08-28-2009 04:21 PM
I like to install duplex receptacles with the ground on bottom for a reason: It makes them look like two chinese faces saying "who?". :whistling2: Thanks, David
spark plug 08-29-2009 10:24 PM
discussion about Rotary Dimmer!
Just one question. You stated in your original post that some switches, including dimmers were installed upside down. How can a rotary switch be determined to be upside down?... (No matter what):laughing::no::drink:Don't Drink and Drive!!!
Scuba_Dave 08-29-2009 10:33 PM
A lot of dimmers these days are not rotary
They slide up & down
Red Squirrel 08-29-2009 11:02 PM
Haha never looked at it that way, though I always found they look like mad faces. :laughing: Some guy called nema must of had a good laugh designing all the plugs we use today. A lot of them look like funny faces.
