Flickering Power Saver Bulb - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2009, 11:39 AM   #1
Stevie
I have a Phillips Genie 14W Energy Saver Bulb in my toilet operated by a corded pull switch. Bulb has been fine for months but today I noticed that when switched off, the bulb is flashing aprox. once every 3 seconds. I have changed it for a normal bayonet type light and it works fine. (When its off, its off!) When I put the energy saver bulb in a different room it operates fine. I am assuming there is a fault at the switch but why has this started happening after years of loyal service? Any ideas please before I start dismantling.. If the switch is faulty, why does it not affect the normal bulb???
stevebooker is offline   Reply With Quote
Old 01-28-2009, 02:08 PM   #2
Man of many hats
wrangler's Avatar
Rewards Points: 354
Oddly, I have a similar problem with a remote control fan/light. Worked fine with incandescent lights, but when I shanged to CFs, they would faintly blink every so often, even though power was switched off at the remote.
Man of many hats
wrangler is offline   Reply With Quote
Old 01-28-2009, 02:20 PM   #3
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Here is a general recommendation for problems with a light socket. Let us know what you find as a solution for your CF.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-28-2009, 02:25 PM   #4
DIYer
CF bulbs can be lit up by just being close to an electrical field. Here check this out:
I did this experiment myself and it works. A CF will light up dimly when it's influenced by any moderate electrical field.
Gigs is offline   Reply With Quote
Old 01-28-2009, 03:56 PM   #5
Man of many hats
wrangler's Avatar
Rewards Points: 354
Thus the electricity feeding the fan, or the field produced by the motor running would provide the energy required to make the CFLs flicker.
Good info, thank you.
Brett
Man of many hats
Old 01-28-2009, 08:05 PM   #6
Rewards Points: 852
You most likely have a "leaky" switch. They get gunked up over time, and start to conduct when in the off position. You would notice a small amount of leakage with the CCFL because it doesn't draw much current, and if it sees a high enough voltage due to the faulty switch, it will fire. Once it fires, it needs to draw more current, and the switch in the off position cannot provide that current, so the lamp extinguishes.
I would start with replacing the switch.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 01-29-2009, 12:46 PM   #7
Stevie
[quote=KE2KB;220985]You most likely have a "leaky" switch. They get gunked up over time, and start to conduct when in the off position. You would notice a small amount of leakage with the CCFL because it doesn't draw much current, and if it sees a high enough voltage due to the faulty switch, it will fire. Once it fires, it needs to draw more current, and the switch in the off position cannot provide that current, so the lamp extinguishes.
You appear to be correct. The switch actually fully failed last night - I shall be replacing. Many thanks
Old 01-29-2009, 12:50 PM   #8
DIYer
Good call KE2KB
Old 01-30-2009, 10:44 AM   #9
Rewards Points: 852
Good call KE2KB
Thanks;
I guess my brain hasn't gone totally to mush yet<g>
FW
Old 02-02-2009, 08:17 AM   #10
Stevie
Changed the switch, everything now ok. When I dismantled the old one the lower half was full of water. The room is unheated and it has been cold recently. I am guessing it was a build up of condensation as there is no sign of leakage from the ceiling. Again, many thanks for the input especially KE2KB.
Old 02-02-2009, 09:33 AM   #11
Rewards Points: 852
If it's that wet in the room, you might want to consider installing a weather protected cover.
FW
Replacing undercabinet halogen bulb with xenon bulb gabbie14 Electrical 10 09-26-2011 11:46 PM
Flickering power... pcampbell Electrical 12 01-11-2009 01:01 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
