Flickering Lights? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-09-2009, 12:27 AM   #1
Flickering lights?
I went into my bathroom the other day and noticed that the lights were flickering. Now today I noticed that all of the lights that are controlled by that breaker all flicker. The bathroom is by far the worst though. When I went to the breaker panel I heard electrical noise coming from the panel. I shut off the breaker and it stopped. And ideas? Loose connection some where, bad breaker? Thanks
sflamedic is offline   Reply With Quote
Old 02-09-2009, 12:34 AM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
Very likely a loose connection in the panel. Again, most likely, would be A 5 minute fix for someone with electical experiance
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-09-2009, 05:05 AM   #3
The breaker may have some worn contacts, get it checked out by a professional electrician if you are unsure. If its is one of those "plugin" style circuit breakers then you should be able to get a replacement and do the job yourself.
Depending on the rating of the Circuit Breaker it should only be a few dollars (doing it yourself)
shezzski is offline   Reply With Quote
Old 02-09-2009, 07:16 AM   #4
I think its a loose hot. Could be the breaker or somewhere in the circuit. Since its worse the the bath, I think its in the circuit. Try to avoid using the lights. Dont want to melt all the insulation on the wires.
Turn the breaker off and check each connection. Use a multimeter to check for voltage.
rgsgww is offline   Reply With Quote
Old 02-09-2009, 08:29 AM   #5
Licensed Pro
Could be loose hot wire OR loose neutral. Start by checking both at the panel and workl back toward the bath.
Help With Flickering Lights! lisarmw Electrical 4 10-14-2008 11:34 AM
flickering lights zircon Electrical 13 10-13-2008 10:38 AM
Flickering Lights Flickering_Lights Electrical 9 09-19-2008 04:52 PM
Flickering Lights nebil17 Electrical 3 08-15-2008 09:42 AM
Flickering flourescent lights in new house Faulknertw Electrical 9 07-30-2008 08:29 PM
