Flickering Light Bulbs - Electrical - DIY Chatroom Home Improvement Forum
Old 04-26-2009, 03:18 PM   #1
flickering light bulbs
I recently extended an existing 20 amp/12g home circuit by tapping into an end-run duplex outlet and installed two new exterior wall lights controlled by a digital timer-switch. The additional length of wire is 30 feet. The bulbs in the new lights pulse and flicker continuously and eventually burn out much faster than normal. I have tried different types and wattages of bulbs but the result is always the same. Most of this circuit is seldom-used and holds only normal-use receptacles and ceiling lights. There is no problem with any of the other bulbs in the run. What could the problem be?
simcao is offline   Reply With Quote
Old 04-26-2009, 06:00 PM   #2
Incand. lamps or CFLs?
Light bulbs burning out Michblaze02 Electrical 12 03-19-2009 01:18 PM
Ceiling Fan Light Bulbs? kennykenny Electrical 7 07-29-2008 08:16 AM
Newbie's lights flicker and bulbs blow out MA_in_PC_Fla Electrical 11 05-21-2008 03:34 PM
clear light bulbs versus white ugabulldog Electrical 5 04-19-2008 11:42 AM
